07-18-2014, 01:48 AM | #1 |
1962 Chevy K20 4X4 LB FS 3/4 Ton
Just bought this 1962 Chevy 3/4 ton 4X4 long bed, this truck has a SBC 350 installed using the front motor mount only. Has anyone set this truck up with using the side motor mounts that are on the SBC 350's? Looking for advice.
Thanks, Semper Fi Bruce Last edited by 63 & 64 Bowties; 07-18-2014 at 08:59 AM. Reason: wtb by non-subscribing member |
07-18-2014, 01:54 AM | #2 |
Re: 1962 Chevy K20 4X4 LB FS 3/4 Ton
why do you want the side motor mounts. as long as you are using the orig b/housing mounting, you will have no problem with it. if you are going to an a/trans then you will have to change it then
ron |
07-18-2014, 09:00 AM | #3 |
and a few others
Welcome to the forum. But, I had to edit your post. You'll have to become a subscribing member to post "want to buy" threads.
A reminder: Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
07-18-2014, 09:38 AM | #4 |
Welcome to the forum and great looking 62 4x4.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-18-2014, 03:50 PM | #5 |
and a few others
Thanks for subscribing and supporting the forum. Feel free to post your wtb.
07-18-2014, 09:15 PM | #6 |
Proprietor of Dale's Corner
Welcome and congratulations on subscribing it's worth it...love your truck
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
07-18-2014, 09:44 PM | #7 |
Nice truck gerebru. My dad and I have a 66 k20. Can you post some pictures of how your engine is mounted in your truck, we are also going to put a 350 in ours. Evan396
07-19-2014, 01:19 AM | #8 |
60-66 Nut
In the past I have used a '67-'72 K series engine mount crossmember in a '60-'66 K10. You just have to drill the bolt holes. Not long ago someone told me that they used a '73-'87 K series engine mount crossmember in a '60-'66 K20 without modification. If that is true, it is possible that the '60-'66 K20 frames are taller? I do know that the '73-'87 K series crossmember will not fit a '60-'66 K10 frame without modification.
07-19-2014, 02:23 AM | #9 |
Welcome to the forum, and congratulations on that awesome truck!
Michael - 1962 C20 LB stepside (project thread) - sold - 1963 Chevy C10 LB stepside (donor) - 1963 Chevy C10 LB Custom flatbed (project thread) - sold - 1979 K20 LB fleetside (project thread) Favorite exchange on the board so far: ol_Curt: "Jason, do you have power steering?" jason65: "No, but I lift weights." |
07-19-2014, 02:55 AM | #10 | |
ron |
07-19-2014, 04:12 AM | #11 |
07-19-2014, 10:45 AM | #12 |
there is no link as it is a friend of mine and he doesn't do any forums. these were some pictures that I got from him. there are a few more pics around. some are in Jon's 4 x 4 suburban conversion and there was a thread that I started here that I will see if I can find. he even cut the frt axle housing down and installed shorter axles so that it would retain orig width. the axles were an over the counter purchase through Dana.
4500 trans with advance adaptor hook up ron |
07-19-2014, 03:33 PM | #13 |
07-19-2014, 05:32 PM | #14 |
Great Truck Congrats
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
07-20-2014, 01:15 AM | #15 |
The Motor has one mount in the front, the old horse collar that goes around the timing chain cover and two on the Transmission which is an original Granny four speed. Im going to use the 350 side mounts just have to get them welded to the frame, I will send pics when done.
07-20-2014, 01:27 AM | #16 |
Anyone know where I can find a 62 Chevy grill, Im also looking for another bed, long that is not as in bad a shape as mine. Ive got a GMC tail gate and also need a Chevy tail gate
Thanks Bruce |
07-20-2014, 01:59 AM | #17 | |
ron |
07-20-2014, 02:01 AM | #18 |
60-66 Nut
I do remember those pics Ron, I had just forgot about the '73+ engine mount. So that engine mount was installed without modifications? I guess maybe I had better clean off my tape measure. I do prefer the '73 and up engine mounts over the earlier design.
07-20-2014, 02:15 AM | #19 | |
ron |
07-20-2014, 03:12 AM | #20 |
Because the new motor im putting in is a 440 HP 350SBC and I don't trust the front motor mount, its cracked, and I cant find a new one anywhere
07-20-2014, 07:26 AM | #21 |
sounds like with all that power you will tear up the drivetrain
07-20-2014, 08:49 AM | #22 | |
this fellow in the following link will have a set of the right 4 x 4 perches for a 63-66 4 x 4 for a sbc as he has gotten the right set for a 292. http://67-72chevytrucks.com/vboard/s...d.php?t=635291 another set-up that one can use is out of a 67-72 4 x 4 which is what I bolted into my 64 there is also different frame heights between the years 60-62 are not as high as the 63 & up; in this link http://67-72chevytrucks.com/vboard/s...d.php?t=550856 you will have to use a spacer on top of the frame to use the later mounts. the alturnative is to fabricate your side mounts. bolt any of them in instead of welding them in, believe that there was also someone on this board recently that said that they had 2 of those orig horseshoe mounts ron |
07-20-2014, 02:57 PM | #23 |
I have a couple of the u shaped mounts
07-21-2014, 12:12 AM | #24 | |
60-66 Nut
Ron, That is true with the C series truck frames, but I believe the K series frames are the same height from '60-'72. That is why I suggested the '67-'72 K series engine mount crossmember.
07-21-2014, 12:14 AM | #25 |
60-66 Nut
In consideration of that fact, I would go with the '73-'87 K series engine mounts and crossmember, even if it needs to be modified to fit your frame. Those engine mounts are far better than the '63-'72 mounts. Are you keeping the SM420 trans and T221 transfer case, or are you upgrading?
