who has the best lowering components?
New to the forum and as the name says I'm building a 68 shortbox Chevy and I want to drop it enough to look cool and handle better, I'm 17 and on a somewhat budget so bags are out of the picture. I see drop spindles and springs in the lmc catalog but don't know the quality of them, so I figured I'd see what you guys were runnin.
![]() Join Date: Jun 2009
Re: who has the best lowering components?
Chumai (hello), Welcome to the forum.
I've been looking into lowering my c20 also, for stance and handling. Usually if you just type in what you're researching into the search at the top of the page (make sure that only this forum is selected for results) you should get more than enough info. Lots of people have done or asked what you're looking into doing. Good luck and include some before/after pics...
1991 Chevy K10, 4x4 ______ Past Rides 1971 Chevy C20 Longhorn (6.6L, 402c.i.); 1973 Chevy K20, 4x4, std. cab, longbed (5.7L); 1979 Chevy Corvette (5.7L); 2001 Chevy Xtreme S-10, ex-cab, 5spd. (4.3L); 2001 Chevy Silverado 2500HD, 4x4, ex-cab, (6.0L); 2002 Chevy Silverado 1500, ex-cab, 4-6drop (4.8L); 2003 Chevy Silverado 1500, 4x4, std. cab, 5spd. (4.8L); 2004 Chevy Colorado Z71, 4x4, crew cab, (3.5L); 2006 HUMMER H3, 4x4, 5spd., (3.5L). |
#3 | |
Early Classic Ent. by far, with customer service to match.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
I second Early classic enterprises. Parts and support seems good.
My only grip with them is: Their instructions for the rear are a bit incomplete, causing some frustration during install. Their front shocks seem too soft, since my inner tire hits the fender over road bumps/drops. Here's my install thread if you're interested: http://67-72chevytrucks.com/vboard/s...d.php?t=612794 |
Ece is pretty much the standard for static drop kits, can't go wrong
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
![]() Join Date: Feb 2008
Not sure what parts you would be looking for, but I am getting ready to list a complete ECE 4/6 drop setup on here/Craigslist in the next week or so. It was just mocked up on my frame, never ran. I've decided to change to a Porterbuilt setup on air. I'm in St. Chuck so would only be about 10 miles away. You'd save a fortune on shipping costs, this suspension stuff is heavy.
1967 Chevy SWB 1972 Chevy SWB 1972 Chevy SWB K20 4x4 1991 Ford F-150 2013 Dodge Ram 1500 4x4 |
I used mcghaughys .. saved $ and every part fit good and works well.
1969 C10 SWB -- LS 5.3 4L60E , CC LT HEADERS, 2.5" X-PIPE ,P&P THROTTLE BODY, CAI, ELECTRIC FANS, 3:73 GEARS, TRAC LOCK, 22" BOYDS , VINTAGE AIR, DAKOTA DIGITAL, 2013 LTZ LEATHER SEATS, PIONEER DD NAVI, 4.5˝ FIBERGLASS COWL HOOD, MCGAUGHYS DISK BRAKE CONVERSION 2.5 DROP SPINDLE 6/8 STATIC DROP . ![]() |
I was in the same boat, and after countless searches on this forum and the web in general, I also went with ECE (Early Classic Enterprises).
I went for a simple 2" drop spindles for the front (with their front disc brake conversion), as well as drop shackles for the rear leaf springs. Haven't installed them yet (trucks not ready for them), but their prices were decent; the kits were complete (not always the case with some vendors); the parts look and feel very well made; and the customer service was top notch. What kind of drop you want may be a deciding factor. Basic 2" drop all around, or a 4-5 drop to get it as low as possible without cutting frames etc. The type of drop you want will effect price as well as vendor/manufacturer. Other things like keeping current and desired brakes, as well as intended use of the truck, will come into play as to which kit you buy. A search of the forum will help you decide the best route to take for your needs. |
![]() Join Date: Apr 2012
Early Classics has outstanding customer service and high quality products. Can't go wrong with them.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
#12 | |
#13 | |
#14 |
![]() Join Date: Jan 2012
Hey Ekliptix, are you running a 7" or 8" wide rally wheel up front, and what size tire?
#15 |
Moderator
![]() Join Date: May 2007
I have all CPP components on my 5/7 drop, will do the same thing again if I buy another truck.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#16 | |
http://www.earlyclassic.com/tech.asp...nce%20Photos-2 Once you get that figured out its really just a matter of how you approach it and the parts you want to use/upgrade. I'm still in the process of breaking everything down, as I said I probably would have listed in the next couple of weeks. You live so close I thought I'd let you know and see what you'd be interested in. Here's a rough starter list of what I will have
#17 |
I just got a y pipe for the same manifolds from Waldron's exhaust.
#18 |
To clarify the rubbing I mentioned with my ECE kit, my tires are all 275/60/15. They are pretty wide, so that could be a big part of the front rubbing over bumps. I'm also an extra 0.5" lower in the front from using an optional 2" drop coil from ECE.
