07-18-2014, 04:04 PM | #1 |
advice on removing rattle can paint
The previous owner of my 62 c-10 rattle canned over the original awesome mint green or whatever the name for it is. Most of the sections are chipping away revealing the original paint and i'd like to get it all back to that and let it patina from there. Any advice or tips for trying to get off the few layers of rattle can and not hurting the og paint all that much? I'm not too worried about going too deep into the og green paint, but just looking for a method that might not take too much paint off and also not take all summer to remove. Thanks so much!
07-18-2014, 04:08 PM | #2 |
Re: advice on removing rattle can paint
I use either thinner or graffiti remover from lowes. Have had good success with both.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-18-2014, 04:54 PM | #3 |
Ditto on the graffiti remover or "Goof Off". If you use thinner, make sure it's paint thinner (mineral spirits), NOT lacquer thinner. The exact type of rattle can paint is everything here. Some will just wipe off, others will be a bear. If a mild solvent won't loosen it, it's going to be a bit risky using a more volatile solvent as that could soften the very paint you're trying to save. In that case, a very fine (and careful) wet sanding and buff-out might be your answer. Too many unknowns to accurately predict an outcome. Be patient and good luck!
07-18-2014, 04:58 PM | #4 |
Depending on how much there is and how much patina you want, a DA and some 400-600 will work quickly, but you'll burn through on some edges, etc. Could end up with a great fauxtina job. The factory sealer/primer is tough stuff, i had some left after doing under the hood with 80 grit (!!!) on the da to remove this tar crap. That yellow undercoating stuff really stood up.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
07-18-2014, 04:58 PM | #5 |
I would love to see before and after pics!
07-18-2014, 05:00 PM | #6 |
Agree............lets see before and after.
Sounds like ALOT of work
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
07-18-2014, 07:24 PM | #7 |
But Found Her 25yrs Later!
I've searched this topic before but somehow missed the Graffiti Remover.
The black paint inside my cab was touched up with rattle can. I will try Graffiti Remover.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-18-2014, 07:44 PM | #8 |
Who Me?
Wait a few weeks, it will just flake off
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
07-19-2014, 11:55 AM | #9 |
I recently bought a 1970 Triumph Bonneville that the PO had "touched up" some of the frame and such. I used acetone and it took the rattle can paint off and left all the original paint. Hit it with some polishing compound and it looks great. I imagine the original paint is lacquer and that may make a difference.. maybe try a small test area..
[IMG][/IMG]
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
07-19-2014, 03:30 PM | #10 | |
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
07-19-2014, 04:06 PM | #11 |
Since I'm planning on saving as much of the original paint on my bedsides figured I give the Acetone a test... Here's the primered/bondo'd panel before
And here is the panel after about 5 minuets of work. The rest of the primer will come off eventually but there was no red paint on the rag.
