Porterbuilt tubular drop crossmember, rear tubular crossmembers, Ridetech RQ shocks
I'm selling these leftover Porterbuilt parts off of my project that I parted out recently. I was hanging on to these crossmembers because I thought I'd use them on my 1971 stepside when I lower it some day but have decided to go ahead and sell them. The crossmembers have surface rust from the frame sitting outside under a tarp.
Tubular trailing arm crossmember ( works with a 1pc driveshaft and factory trailing arms) These are 249.99 new. Price is 225.00 shipped Conus **Sold** Rear crossmember ( mounts behind the rearend ) $65.00 shipped **Sold** Very rear crossmember $65.00 shipped **Sold** New these crossmembers run 75.00 each I still have the Ridetech RQ shocks available. 17" extended 11" collapsed $175.00 shipped These shocks new cost $125.00 each **Sold** Thanks, Scott Duckworth 913-314-6233
Scott Last edited by sduckworth13; 07-19-2014 at 10:19 PM. |
Re: Porterbuilt tubular drop crossmember and two rear tubular crossmembers
Drop center crossmember
Scott |
I also have a set of Ridetech RQ drop shocks that I'm selling. They are brand new and used only for mock up. $175.00 shipped CONUS
http://www.azproperformance.com/Ride...-22149811.html
Scott Last edited by sduckworth13; 07-18-2014 at 07:45 PM. |
Re: Porterbuilt tubular drop crossmember, rear tubular crossmembers, Ridetech RQ shoc
Are these adjustable shocks like Qa1 and do you know the extended and collapsed length
///Relaxed Atmosphere |
No they aren't adjustable.
Scott |
Jeff, I'll check the extended length on those for you when I get back home.
Scott |
Jeff, I checked the extended length and it is 17" eyelet to eyelet and collapsed length is 11" eyelet to eyelet.
Scott |
![]() Join Date: Jul 2009
Pardon my ignorance, but the trailing arm crossmember...will it work with PB trailing arms too, or only the stock ones? If it'll work with the PB trailing arms, I'll take it.
The trailing arm crossmember is made to work with the factory trailing arms and it's for a one piece driveshaft.
Scott |
The one piece d/s is fine. I'm only using a small PB notch so I won't be really low or high. Mild is the key here. The PB site says the PB trailing arms fit the stock crossmember?
Cool, I'll send you my paypal info. Thanks for double checking.
Scott |
Payment sent for all 3 PB cross members
#13 |
Payment received for all of the Porterbuilt crossmembers. Thank you! Can you please send me your shipping address. I'll get the crossmembers shipped out Monday after work and send you the tracking numbers.
Scott |
#14 |
Scott,
PM'ed you my Address. Thanks |
#15 |
Got it, thank you.
Scott |
#16 |
![]() Join Date: May 2009
#17 |
I can do that. Here is a picture of the shocks and the two shock studs will be included with the purchase
Scott |
#18 |
#19 |
PM on the way
Scott |
#20 |
Payment received, thank you. Shocks will get sent out on Monday.
Thank you guy! Appreciate it! Everything has been sold.
Scott |
#21 |
Are you selling the upper and lower shock cross members that bolt to the frame and to the trailing arms?
#22 |
I was going to keep the rest but if you want the 2 piece c-notch, shock crossmembers and the extendable trac bar I'll take 600.00 picked up because I see your close or 675.00 shipped.
Scott |
#23 |
The top tubular shock crossmember mounts to a bracket provision on the c-notch and the trac bar uses the same bracket that mounts on the trailing arm the lower shock crossmember does on the passenger side.
Scott Last edited by sduckworth13; 07-20-2014 at 12:43 PM. |
#24 |
![]() Join Date: Apr 2011
#25 |
Scott |
