Giddy up giddy up...
Best cab mounts?
I'm looking for a complete body mount kit with bolts and all. Rubber or that poly stuff, doesn't really matter, I just need the best price and fast shipping! I didn't pass inspection the other day cause the guy didn't like my mounts and I'm going to college in a couple weeks
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site... |
I have not installed the ones that I bought yet, but they look really good. I bought my complete set of rubber mounts with hardware from Tim Christian and other parts from him have been good quality.
Jim |
LMC's kit is $99.95
I should point out that this price is for rad support/cab/bed all.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. Last edited by palallin; 08-06-2003 at 02:36 PM. |
Resident Curmudgeon
![]() Join Date: Dec 1999
I know you have a body lift so 'm not sure how that affects your decision, but for a stock 4x4, the 3/4 ton 2wd kit is the correct item to buy. I just bought a 2wd 1/2 ton kit from GMCPauls for <$60 delivered. This included all rubber, bushings, washers, bolts, etc. It was dropped shipped from Brothers I beleive and arrived in approx 1 week. I have used his 3/4 ton 2wd kit on a 4x4 with no problems. All the vendors sell essentially the same thing. Check around and see who can deliver it the fastest. You did not state what the inspection found wrong, you may be able to get buy with just a partial kit as they sell the pieces individually as well.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Thanks for the replies
![]() It was actually the body lift that the inspector did not like but the rubber in my mounts are all shot anyway. I just wanna start off fresh with a new body mount set and get the body back to stock height. CPNE, does that kit come with mounts for the bed as well? $60 is a great price but I need to do both cab and bed.
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site... Last edited by Chevy409; 08-06-2003 at 02:15 PM. |
Resident Curmudgeon
That is for cab only. Again, only speaking stock applications, the bed bolts directly to the frame using 8 carriage bolts with nuts and lock washers. Basically hardware store stuff
Oh ok, cool. I just thought there were rubber spacers or something that went between the bed and frame. Thanks for the help
I have 2wd and 4x4 in stock if interested? Thanks I can ship right out also.
Resident Curmudgeon
There ya go. Can't go wrong with Tim
#10 | |
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#11 | |
Resident Curmudgeon
All right, thanks again for the insight everyone, I really appreciate it, especially with my pinch for time.
![]() Tim, I'm not sure what I'm going to do. The two things the inspector really cringed at were the ungly body lift and the fact that there were no rubbers for the bed... but, since there's no need for anything but a bolt to hold the bed down, maybe he'll give me a sticker now. There's really no reason why he shouldn't, it's not like body lifts are illegal in my state. I'm going to run back over there tonight (he's only a few miles away) and see what he thinks. If I end up still needing some mounts, I'll get back to you by this evening. Thanks a lot.
#13 |
its all about the +6 inches
Where are you located, so I know not to ever consider moving there.
Must be PA. |
#14 | ||
Where's my beer?
Paul How do you make the invisible, visible?.........You take it away. |
#15 |
I'm in NH and I guess, in my area at least, they're starting to crack down on lifted rigs.
I brought my LMC mag. in hand tonight to show the guy there's no rubbers out back and he himmed and hawed for another 30 minutes but I got my sticker today. For future inspections though, I think I'm going to look into "Farm" plates. I only drive the '72 in the winter, don't go very far cause of gas, and at least then I could jack the thing sky high and just say I have a muddy farm or something. I don't know, any reason why that wouldn't work?
