![]() Join Date: Jun 2013
16 inch 6 lug steel wheels?
gonna be installing c10 rear in my c20 when i replace trailing arms was wondering what 16 inch 6 lug i could use to match the front(f__d steel wheels)gonna have 8 lug on front untill i get to front crossmember
![]() ![]() Join Date: Jul 2002
Re: 16 inch 6 lug steel wheels?
The closest & cheapest would probably be the stock steel wheels from 88-98 4x4s
60-66 Nut
![]() ![]() Join Date: Mar 2007
The hub holes on those will have to be opened up to fit the early C10 hub register. That or have the hub registers on the axles turned down.
I would say the best would be a set of original 16" 6 hole wheels. I do have some of those, but shipping would be spendy.
#4 | |
thanks for the input had seen on previous thread about center hole being to small on 88-98 wheels.would it be better to turn down axles?
60-66 Nut
If you plan to run the '88 and up 6 lug wheels for longer than temporary, I would have the wheels machined. You could have the hub register on the axles turned down, but I don't know if that will be possible on the front hubs, not knowing just what rotors you plan on using. If I'm not mistaken, the '88 and up 6 lug wheels have a 3-1/16" hub hole. The newer wheels are wider than the early wheels, but they also have a deeper backspacing. I would suggest checking the backspacing to see if that will be an issue, before having any machine work done.
