Old 07-18-2014, 09:22 PM   #1
Truck Guy99
Random squealing from rear end in revers, low forward speed, and turning
05 chevy silverado 1500 2wd has a strange squealing sound coming from the rear end. When you put it in reverse it makes a squealing sound but only when it's rolling. When going forward at low speed it squeals but when you get above about 5mph it stops. It also happens when you make a somewhat sharp turn at speed above about 15 mph. We replaced the rear drums, front rotors, and front brake pads a few days after this happened and it continued. Old drums and rotors did not have any grooves indicating uneven wear, they were just worn thin from everyday wear. What could cause this squealing? It isn't the sound of brake drums or discs dragging (I know that sound a little too well from my last truck) but it definitely sounds like metal on metal
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
Old 07-23-2014, 12:22 AM   #2
kev63rod
kev63rod's Avatar
Re: Random squealing from rear end in revers, low forward speed, and turning
my bro had a had sub that did that and it was a tight/dry u joint. it was really annoying.
blessed are they that expect nothing, for they shall not be dissapointed
kev63rod is offline   Reply With Quote
Old 07-23-2014, 07:59 AM   #3
95 S_Trucker
95 S_Trucker's Avatar
How rusty are the backing plates?. Up north, they cause all kinds of strange noises when the rust.
95 S_Trucker is offline   Reply With Quote
Old 07-25-2014, 11:02 AM   #4
stroker87
axle bearings? i had the same type of problem replaced the bearings
stroker87 is offline   Reply With Quote
Old 07-29-2014, 09:22 AM   #5
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
x2 U Joints...mine did that about a month ago, and I replaced them...no more squealing!
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 08-11-2014, 03:51 PM   #6
CubFanMan1
My truck did the same thing, and mine got worse as time passed. I had the U-joints and carrier bearing replaced, and the drive shaft balanced and now no more squealing.
03 Crew Cab 2500HD 6.0
CubFanMan1 is offline   Reply With Quote
Old 08-11-2014, 08:50 PM   #7
Truck Guy99
How do I know if it's the u joint at the trans or the differential?
Old 08-11-2014, 09:34 PM   #8
CubFanMan1
It doesn't really matter. The whole drive shaft will need to be removed to make the repair so might as well replace them both.
I put the rear end up on jacks and had a friend check to hear which one was making the noise while I put the truck in drive. Mine was the one up front.
Old 08-13-2014, 11:14 AM   #9
Mr-Jack
Mr-Jack's Avatar
get the good joints too and make sure that you chock the tires and set the e-brake
Old 08-13-2014, 03:25 PM   #10
Truck Guy99
What joints do you suggest?
