NEW harnesses available.
Ok, I've sent a few of these out already so I thought I'd post a couple pics of my latest offering. I'm am building my inventory of serpentine engine harness swaps and front lighting harness with relay upgrade. This is for a stock headlight style for those who wish to increase output of factory headlights-and the 4-HI option on 81-up trucks can be included upon request. The serpentine swap incorporates built-in CS alternator harness with 68-ohm resistor, oil pressure switch, HEI lead, starter solenoid lead, wiper motor/washer (wiring depends on year), temp switch, fuel level lead and carb choke along with BAT leads which In include a remote junction to take advantage of the newer, higher output alternators' remote voltage sensing.
These harnesses replace your existing bulkhead connector on the firewall. PM for details as there are subtle differences through the years....if you are swapping a newer column in an older truck for example, the bulkhead connector would need updated accordingly.
This post is meant as a notice that I have these harnesses available, PM for specifics.
