Old 07-19-2014, 10:16 AM   #1
Slinger60
Slinger60's Avatar
Anyone seen these before?
These are on a 1970 c/20 truck never seen anything like them before. They look like some kind of torque strap. The one on the passenger side was bolted to the a/c bracket that I removed. Factory installed?
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 07-19-2014, 10:22 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Anyone seen these before?
Dealer installed tiedowns for when the motor mounts break. I have seen them quite a few times and have a few NOS sets also.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-19-2014, 10:39 AM   #3
FL71C10
They were a fix for stuck throttles on trucks until 1971, when they switched to throttle cables.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 07-19-2014, 10:49 AM   #4
dirtyjim
dirtyjim's Avatar
they are a good idea, you would be surprised how much a engine can jump up if you beak the driverside mount. I had the driverside mount mount on a tunnel rammed big block break while I was getting on it. the engine cam up and over a good 5". luckily the hood was originally cut out for a mr gasket street scoop and I just had two small air cleaners on it at the time or I would have needed a new hood
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 07-19-2014, 11:46 AM   #5
hugger6933
while being quite young still at the time, I do remember such things and the dealers could not keep these things early it seems. So being that most farmers are part engineer and if you hand them duct tape and zip ties that feeling will double. But back then in that day it was mechanics wire and in this case a couple of bolts and a short amount of chain to limit the torquing over the engines. Little did everyone know we were just a short redesign away from solving the motor mount crisis. Jim
hugger6933 is offline   Reply With Quote
Old 07-19-2014, 12:00 PM   #6
Lee H
Lee H's Avatar
Yup, early motor mounts broke quite easily as the torque and HP increased through the 60s & early 70s. The quick fix, these straps and were used on most GM cars that had came in for broken motor mounts. The mount was replaced and then these straps were installed. Lots of bolts and chains for the DIYer. GM fixed the issue with a redesigned motor mount that had a couple of interlocking tangs that limited the distance the mount could separate and prevented the rubber from tearing.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-19-2014, 12:57 PM   #7
Daddy'O
Daddy'O's Avatar
Cool - I learned something today. You've got to love this site!
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 07-19-2014, 01:28 PM   #8
Grumpy old man
Grumpy old man's Avatar
I found a nos set on e-bay for $22.00 in the box a few months back They make a few different models and have one specific to our trucks
Grumpy old man is offline   Reply With Quote
Old 07-19-2014, 04:48 PM   #9
FirstOwner69
FirstOwner69's Avatar
These were installed as part of a safety recall campaign sometime in the early 70s to restrain the engine and prevent solid throttle rods from sticking in the open position.
FirstOwner69 is offline   Reply With Quote
Old 07-19-2014, 08:49 PM   #10
Tinkermc
I have seen them b-4 but never heard the story, thankZ
Tinkermc is offline   Reply With Quote
Old 07-19-2014, 10:06 PM   #11
TheOtherScott
Man I wish I had at least one of those installed on an old Pontiac about 30 years ago! As others have described, the drivers side motor mount broke and the motor torqued over. Sucked the accelerator right out from under my foot; just floored that 389 on a neighborhood street. I shut off the key the first time. Second time I just rode it out. Pretty exciting but I fixed the motor mount anyway...
TheOtherScott is offline   Reply With Quote
Old 07-19-2014, 10:25 PM   #12
davepl
davepl's Avatar
My 2+2 lost them somewhere and sure enough, when the mount broke the engine lifts, the throttle rod doesn't, and bye bye! So we poverty kids just used bolts and chain.
But it'd be nice to have a clean new set, I wonder if they're still around for big blocks?
Brain teaser: did they really need one on the passenger side? Does the engine torque the other way when you're backing up, or since that force is reversed in the transmission, does the engine still torque up the driver's side?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-19-2014, 10:33 PM   #13
TheOtherScott
I would say if you're downshifting to slow down then the engine would torque over the other way so the passenger side tie-down would be useful.
Old 07-19-2014, 11:15 PM   #14
kowboy63
my 70 has them. I have also wondered if these were factory or dealer installed.
kowboy63 is offline   Reply With Quote
Old 07-20-2014, 04:32 PM   #15
outlaw 3454
outlaw 3454's Avatar
those things were a recall, i put so many of them on i got sick of em!! lol,
gm got mad at us once cause we had too many of them and i told em some of these car and trucks were crashed and totaled and in the junk yard!! they didnt care so we went to the junk yard and installed alot of them. those with no motors were fun! hehehe
outlaw 3454 is offline   Reply With Quote
Old 07-20-2014, 06:35 PM   #16
Grumpy old man
Here are a few pics of the NOS kit I found on Ebay for $22.00 if you find one buy it can't get more correct than having one installed on your stock ride ? I just looked at ebay $60-100.00 today !
http://http://http://http://
