07-19-2014, 05:23 PM | #1 |
Active Member
A/C flapper valve
Can someone with factory A/C please post a pic of the spring on the flapper valve in the Pass side cowel
07-19-2014, 05:39 PM | #2 | |
Re: A/C flapper valve
Jim |
07-19-2014, 05:44 PM | #3 |
Active Member
Ok, and thanks for pic
Can you show it installed? |
07-19-2014, 05:56 PM | #4 |
Old member
Here is what the manual shows.
07-19-2014, 05:56 PM | #5 |
Here's a link to the thread I mentioned above with pictures.
http://67-72chevytrucks.com/vboard/s...d.php?t=627624 |
07-19-2014, 07:26 PM | #6 |
Old member
Sorry I can't. I deleted it all on my 71 to make it colder inside. I took it all out and blocked it off with sheet metal to make the AC cool better. I also made the passenger side flapper in the cab manual so it stays open all the time to recirculate the cab air instead of bringing in outside air all the time.
