Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-19-2014, 06:31 PM   #1
Jurassic-1
Jurassic-1's Avatar
WTB Power steering bracket
Looking for bracket and wheel well for a factory power steering on a 1964 c-10 We were told there is a hole in the wheel well with a clamp type bracket. I need to locate one. Does anyone have a photo of this unit?
Jurassic-1 is offline   Reply With Quote
Old 07-20-2014, 12:57 PM   #2
sigshooter
sigshooter's Avatar
Re: WTB Power steering bracket
No hole in the wheel well or bracket, that I have ever seen anyways. There is a bracket that holds the hoses that bolts to the top inspection cover on the gearbox.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 07-22-2014, 01:41 AM   #3
t korinek
Truckin' Krazy
t korinek's Avatar
we just got this piece, its not a 67-72 thinking maybe for a 64-66, look familiar?
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
Old 07-22-2014, 09:19 AM   #4
60-66
60-66's Avatar
The hole in the inner fender is correct for GMC only. PS hose routing was different.
https://67-72chevytrucks.com/vboard/...1966+gmc+panel
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 07-22-2014, 10:18 AM   #5
Jurassic-1
Jurassic-1's Avatar
Thanks for the info. Do you know if Chevy had an extra bracket where it went under the fender well? it rubs the hose.
Old 07-22-2014, 10:23 AM   #6
Jurassic-1
Jurassic-1's Avatar
Tom , What is left on that system? the 64 box is different from the 67-68 box. Chris is trying to get info for his build but I may be putting power steering on my 66. Thanks. Also Chris still wants fenders and doors for his 65 4x4. Give him a call if you get any nice ones Thanks
Old 07-22-2014, 10:28 AM   #7
60-66
60-66's Avatar
Yes, it mounted to the steering box as sigshooter pointed out above. The system pictured here above looks correct for 63-66 but are you doing a half or 3/4 ton ? 3/4 ton center link is different.
Old 07-22-2014, 06:36 PM   #8
60-66
60-66's Avatar
Heres the Chevy bracket, mounts to steering box and passes under the inner fender
Then heres a few on the GMC V6 version.
Old 07-22-2014, 07:59 PM   #9
Jurassic-1
Jurassic-1's Avatar
Looks like the V6 GMC Power steering was on the top of the engine so those had the hole through them.Thanks for the photos they show the hoses clearly I think we will have to put a sleeve over the hose. You can see how the fender well left a mark on the hose sleeves. Thanks again for the info.
Old 07-23-2014, 09:51 AM   #10
GMCNUT
GMCNUT's Avatar
Tom are you selling this drag link, control valve and steering box etc? PM me if no one else has dibbs and you want to get rid of it.....thanks!
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 07-23-2014, 10:05 AM   #11
t korinek
Truckin' Krazy
t korinek's Avatar
The whole assembly is for sale, the steering box, drag link,brackets etc, everything in the pics Jurassic has first shot at it, if he passes GMCNUT is up $135 + shipping
Dealer for:
American Auto Wire
Dakota Digital
Trim parts Carpets
& Many others
Old 07-23-2014, 11:14 AM   #12
Jurassic-1
Jurassic-1's Avatar
Tom I still have the 3/4 ton 1968 setup . I may try to put it in changing only the brackets. I will pass since I do not want you to have to part a complete one out Gmc Nut can step in but if you get a partial frame bracket set let me know .Thanks
