07-19-2014, 08:17 PM | #1 |
carburetor
Hey guys just a quick question, is it possible to remove this stud i have circled so i can install a solid bar style throttle linkage?
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713 Member of tailgate association of manitoba |
07-19-2014, 08:23 PM | #2 |
Re: carburetor
What king of carb is that? Pre-QJet 4MV or 4GV or whatever they were? Curious!
07-19-2014, 08:26 PM | #3 |
Re: carburetor
i just did a google search for quadrajet i have one from an 78 half ton i believe
07-19-2014, 09:43 PM | #4 |
Re: carburetor
Yes you can remove that stud. You'll need a cutting disc on a grinder though. Hacksaw won't touch it. It's hardened metal.
07-20-2014, 08:37 AM | #5 |
Re: carburetor
Do I want to grind off the rear rivet like piece or do I want to cut as close a possible to the arm?
07-20-2014, 09:18 AM | #6 |
Re: carburetor
THe one I did IIRC I cut it off on the front side close to the arm. Then punched the rest
out. Easier to grind/cut that way. |
07-20-2014, 12:14 PM | #7 |
Re: carburetor
All done appreciate the advice guys check out my thread for the end results
