Old 08-06-2003, 03:23 PM   #1
bucket
bucket's Avatar
head bolt sealant
i need to take care of my leaking head bolts........
is it ok to take them out and put back in one at a time? or should i loosen all then retorque in sequence. do all head bolts thread into water jackets or just the lower ones?
bucket is offline   Reply With Quote
Old 08-06-2003, 09:05 PM   #2
bucket
bucket's Avatar
anyone?
Old 08-06-2003, 09:24 PM   #3
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
I would go ahead and pull the heads and replace the gasket also. If you back off the bolts there is a chance it could damage the gasket. it might not happen, but is possible. Secondly no not all the bolts go into the water jackets. For sealant I would use permatex #2 on the threads, and make sure you run a tap down the holes and clean the bolts. any junk on the threads can affect the torque. On the bolts that dont get the sealant use a little oil as the torque specs are what they call "wet".
good luck
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 08-07-2003, 12:17 AM   #4
Nelson
I just did mine, I agree with everything OldYeller said!
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
