07-20-2014, 05:00 PM | #1 |
Brake lines for front calipers
Hey all,
Read through the disc brake reference thread, but didn't see what I was looking for. I'm after some info/photos of the brake line setup for the front of the truck for those that have done a disc brake conversion. I have an 85 front end under mine, but it's been awhile since I had any brake lines on the frame, so I can't remember how it was routed before, and how much it needs to change with the new setup. I'm trying to figure out the following:
Any photos people have of how their softlines are mounted/run would be awesome! Thanks all! |
07-20-2014, 06:24 PM | #2 |
Re: Brake lines for front calipers
Heres some pics of the 61
We did. It has a 79 front end under It with 1 1/4 rotors This is the pass side looking back
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
07-20-2014, 08:14 PM | #3 |
Ah okay, so bolting it to the A-arm is all the mounting it needs huh? I assumed it had some hard mount at the junction, but appears not.
07-20-2014, 08:32 PM | #4 |
It will need a mount at the hard line. a bracket and C-clip. Ours is not complete yet. But gives you an idea of how to route the lines. These are stock lines from NAPA about $16.00 each The clip is already on the line and a small bolt holds it to the A-arm
07-20-2014, 10:48 PM | #5 |
Ah okay so in that photo on the right there will be some bracket you'll make and hang off the frame?
07-21-2014, 03:50 AM | #6 |
I am using the same parts as you mentioned. The new lines have a metal part attached that fits into a hole in your upper control arm. The line is long enough to fit in a hole in your frame. The line has a clip on it to keep it up against the frame and you will have to find a nut that will fit the line on the inside of the frame. I got a couple of them at Fasteners in town. Your small line off the metering block will screw into the new line. You will probably have to make new lines for your front brakes and definatly will for you rear brakes.
66 shorty |
07-21-2014, 10:42 AM | #7 |
Never Ending Projects
Factory disc trucks have the lines on the front side where the drum brake ones had them to the rear of the crossmember. When I converted my C10 panel, I made new lines for the front and mounted a bracket in the approx. location that a stock disc brake setup would have. This routes the soft line from the front to the rear and keeps any tight bends out of it and allows freedom to move as the suspension cycles up and down.
Sorry for the blurry pic but this is the bracket I mounted.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-21-2014, 10:49 AM | #8 |
Not sure how the 85 front crossmember mounts compared to the 63....but you can see the factory soft line mount here in this pic. Hard line will meet it on the back side of the frame. As stated above...just has a c-clip to hold the line in place.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-21-2014, 01:48 PM | #9 |
THanks for the photos! Does anyone have a shot of just the bracket? Does it just have a hold in it, or is it shaped in any certain way?
Also, anyone have a shot of the end of the softline that connects to the hardline? I'm guessing they're unique as well, and a universal line from Summit wouldn't work? From what has been said it appears it has inner and outer threads? |
07-21-2014, 02:12 PM | #10 |
Mine is welded to the frame and just has a round hole in it for the line to come through. Once the line comes through the c clip attaches. I'll check and see if I have any better pics of the tab.
Heres a few more of the tabs on the crossmember (upper a arms removed in the pics) and a good diagram showing the hard line and the soft line connection. Tab goes between them.
07-21-2014, 02:31 PM | #11 |
Sweet, thanks again!
07-21-2014, 02:32 PM | #12 |
There are a handful of places that sell weld on tabs, where you pretty much mount as needed. Summit has a large selection....do a search under "brake line tab" and it'll pull up a bunch....cost around $3-4 each
07-22-2014, 12:43 AM | #13 |
60-66 Nut
The '71-'72 hoses are shorter and will attach to the tab on the crossmember as in 1963c-10's pic. The '73-'87 hoses are longer and attach to the uper control arm and then pass thru the frame where the hard line connects. This is basically what 64tantruck showed in his pic. IIRC there is an oblong hole in the '63-'66 frames that can be used for the brake line.
07-22-2014, 03:40 AM | #14 |
I think an issue that should be discussed is LENGTH and ROUTING of the flexible line to the front calipers. There is so much variation in geometry here that it makes it very hard for a guy to install the lines and know for sure its right. And let's face it. It has to be right.
I just had a Brand New braided steel flex line fail...... And the truck hasn't even hit the road yet. Just rolling in and out of shop. If I had taken a maiden voyage it would have been really bad, and the braided stuff is supposed to be better than rubber. So naturally now I am very interested in getting this part right. It failed right at the crimp, as if the line was stressed too much. But it was all brand name stuff from the guys we all know, as a kit. |
