08-06-2003, 03:41 PM | #1 |
Side Window Question
Looking at what needs to be done to my '67. All the saide window rubber, felt, etc needs replacement. It opening up the door and looking inside I found surface rust on the regulator mechanism and rust on the channel the window sits in. I saw two regulators on e-bay, but the channel the window sits in was not in the picture. Is that part of the regulator assembly or is it attached to the glass? I think mine needs replacement (it is starting to exfoliate and flake off) but don't know what part to look for.
Anyone done this? Thanks.
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
08-06-2003, 03:45 PM | #2 |
Resident Curmudgeon
The channel is affixed to the glass, it is not part of the regulator. The regulator has plastic rollers that set in the channel's track.
You may want to locate some replacement windows complete with channel. Not sure if you can buy the channel separate and have a glass place instll it for you. FYI, the 72 regulators and door latches are different than 67-71. The rods on them protrude further out to compensate for the 72's moulded plastic inner door panel.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all Last edited by CPNE; 08-06-2003 at 03:47 PM. |
08-06-2003, 04:21 PM | #3 |
Windows Channel
Thanks for the info. Might be able to clean these up and hit 'em with POR or some other rust stopper.
08-06-2003, 09:06 PM | #4 |
e mail me if you need channels, i have a ton of them and the glass setting tape for them, we also have the complete glass weatherstripping kit and regulators. new and used glass and vent windows.
Rest in Peace Ed. Thanks for all the good times. |
