Old 08-06-2003, 03:54 PM   #1
still w.i.p '68
Dreams are free
still w.i.p '68's Avatar
Tach problems
I just put a tach in my truck, a mallory.
green wire to neg side hei.
red to switched power.
black ground.
white to lights
orange ? shift light-rev limiter?? not hooked up
any way I was givin this tach, without instuctions,
and this is typical wiring I think,
it doesn't work, Is there a way to test to see if its
any good, or have I done something wrong?
any help would be greatly appreciated....John
'68 swb fleetside
originally w.i.p '68
member since 1-01
w.i.p = ( work in progress )
still w.i.p '68 is offline   Reply With Quote
Old 08-06-2003, 04:48 PM   #2
speeddemon
speeddemon's Avatar
Do you have the green wire pluged into the terminal on the HEI that is labeled tach? It should be just to the left of the power wire going to the HEI.
Demon
69-C10 LWB
71- fleetside shortbed
It's a shame stupidity isn't painful
Never play leapfrog with a unicorn
speeddemon is offline   Reply With Quote
Old 08-06-2003, 05:24 PM   #3
still w.i.p '68
Dreams are free
yes
'68 swb fleetside
member since 1-01
Old 08-06-2003, 06:05 PM   #4
speeddemon
speeddemon's Avatar
Ok. From what you have described you have it wired up right. If all your connections are good and the tach is switched to 8 cyl. Then the tach must be bad
Demon
69-C10 LWB
