07-20-2014, 09:27 PM | #1 |
Window regulator help
Searched the forum but can't find the info I need. Trying to install my side glass in my 70 c10 but can't figure out what the lower roller on the regulator goes into. I know the 2 upper roller go into the track that attaches to the bottom of the window itself but can't figure out the lower one. What/where does it go? What does the track look like? Is it a detachable track or is it made into the door itself? Any pics would be great, I'm lost......
07-20-2014, 09:50 PM | #2 |
Re: Window regulator help
It is indeed a tract that the lower roller goes into, I think it may be spot welded into the door shell itself. If you can get inside there with your fingers it should be toward the back from the middle and just below the part that unbolts. I will watch this thread to see if you get any better answers I have a door at my shop with the skin cut off right now leaned up against the frame chain cart. I'll look at that door to see if I can better direct you. Jim
07-20-2014, 09:58 PM | #3 |
Thanks Jim, I'll look at it tomorrow to see if I can get to it
07-21-2014, 12:16 AM | #4 |
Active Member
Hugger is right Its on the door
07-21-2014, 07:10 AM | #5 |
Thanks everyone, I got it figured out. Thanks for the help!
