Old 07-21-2014, 10:50 AM   #1
Vinnie78
66 VIN Help
I've been pouring over the board and the internet for the last week looking for an answer on this and have almost given up. When I got my truck, the PO signed over the title and I took it to DMV, retitled it, no problem. The problem is, my VIN looks nothing like any of the others I have seen. I also can't seem to find anything on the truck itself. The number on the title is "I1002PD13211A". Any advice?
Vinnie78 is offline   Reply With Quote
Old 07-21-2014, 10:59 AM   #2
jtrichard
Re: 66 VIN Help
any pics of the truck and the vin tag?
jtrichard is offline   Reply With Quote
Old 07-21-2014, 11:00 AM   #3
Vinnie78
Re: 66 VIN Help
I haven't been able to find a vin tag. Is there anywhere that the number would be stamped?
Old 07-21-2014, 11:05 AM   #4
1963c-10
1963c-10's Avatar
Re: 66 VIN Help
Looks like a gmc vin id. GMC vin #'s were much different than chevy vin #'s. You should find a matching serial number on top of the frame rail inside the engine bay. Driver side over top of where the a-arm sits.
Edit: 7/22 No frame stamp on the GMC's
I1002PD13211A
I = Inline engine
10 = 1000 series
02 = 127" wheel base
P = Pontiac plant'
D = inlined engines for 66 gmcs
13211 = serial #.......they started at 10,0001 that year
A = 6,000lbs gvw or less
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-21-2014, 11:48 AM   #5
Vinnie78
Re: 66 VIN Help
Perfect! Thank you! I was starting to get a bit worried.
Old 07-21-2014, 11:54 AM   #6
1963c-10
1963c-10's Avatar
Re: 66 VIN Help
No worry....vin looks correct for your truck.
Good link for GMV VIN's : http://6066gmcguy.com/VinNumber.html
Old 07-22-2014, 12:26 AM   #7
Captainfab
60-66 Nut
Re: 66 VIN Help
As far as I know the GMC frames are not stamped with the VIN. All the OP will have to go by in the tag in the door jamb. Hopefully it is present.
Old 07-22-2014, 08:08 AM   #8
1963c-10
1963c-10's Avatar
Re: 66 VIN Help
Sorry.....couldn't remember 100% if the GMC's were frame stamped
Old 07-22-2014, 08:11 AM   #9
Old Truck Man
Old Truck Man's Avatar
Re: 66 VIN Help
I agree with captain fab . Ive never seen or owned a GMC that had the vin number stamped on the frame. if the tag on the door jamb isn't there you more or less have a truck without a valid title.
Old Truck Man is offline   Reply With Quote
Old 07-22-2014, 08:55 AM   #10
Vinnie78
Re: 66 VIN Help
Thanks all for the help! Unfortunately, there are no tags that I could find. I haven't gotten through all of the boxes of parts yet, so it could be laying in the bottom of a box, but it definitely isn't on the truck.
