Old 07-21-2014, 09:50 PM   #1
WhiteWhale
WhiteWhale's Avatar
HO52 Pinion retainer gasket
Changing out my pinion seal which I already have but for the life of me cannot find the seal for the 5 bolt retainer plate. Ive read that most use RTV but I would like to use the gasket if there is one available. The official part number is 3843067 but I cannot find an crossover number.
Anyone have a source?
WhiteWhale is offline   Reply With Quote
Old 07-21-2014, 11:37 PM   #2
67ctener
67ctener's Avatar
Re: HO52 Pinion retainer gasket
I don't think there made anymore. From what I understand these Easton's are like dinosaurs. You can get some gasket paper and make one yourself.
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 07-22-2014, 08:36 AM   #3
71K20chevy
71K20chevy's Avatar
RTV is about your only option...I've got my H052 ripped apart (destroyed spiders and carrier) and I'm just replacing it with a 14 bolt because you can't get parts for these things!
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 07-22-2014, 11:49 AM   #4
WhiteWhale
WhiteWhale's Avatar
That particular gasket is the only maintenance part I cannot find for it (other than a new r&p). Yes they are a bit more expensive than a 14BFF but since the only problem with it is the pinion seal I cannot see swapping out the axle just for that.
All the following parts were available at AutoZone, Oreilys, and Napa
Hub Bearings
Inner KD11786y
Outer KB111630z
Seal 2081
Axle flange seal 55350
Permatex Gear Oil RTV 81182
Center Section
Pinion Seal 411330n
Repair Sleeve 99259
Retainer Seal 3843067 (NLA)
3rd member to housing seal RDS5090
Cover to housing seal RDS5088
Brakes
Wheel cylinder Left BHH WC49680
Wheel cylinder Right BHH WC49681
Wheel cylinder repair kit BHH WCK13620
Shoes BB248
Rear Hose BH 36684
Drum BBR 2079DGS
Randys sells a Yukon gear overhaul kit for just under $500 which is a bit steep and I dont think I would spend that much to rebuild it and only at that point would I consider swapping it out.
Just wondering how you killed your Eaton?
