Old 07-22-2014, 12:17 AM   #1
spgill2000
Front buckets w/console in rear of 73-87 crewcab?
Probably been done....searched on here for pics or info for hours. Nothing.
So, my question is: Will factory front 73-87 buckets mount in the rear of a 73-87 crewcab?
Anyone have pics of this done? Mounting or bracket tips? Suggestions?
I'm swapping in a set from a suburban up front and I have a line on a 2nd set. They're an exact match with console. This HAS to have been done before...no?
Thanks for any info or help!
I could swear I ran across a pic of a crew with 4 blue cloth buckets and 2 consoles on here somewhere...
spgill2000 is offline   Reply With Quote
Old 07-22-2014, 11:51 AM   #2
spgill2000
Cool Re: Front buckets w/console in rear of 73-87 crewcab?
C'mon...50 views and not a word? Gotta be someone who did or tried this?
Old 07-22-2014, 12:00 PM   #3
Chevy3+3
I can't answer your question if its been done before but I don't see why it couldn't be done. Just buy the set and try it. Anything can be modified to fit.......usually.......
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205
Chevy3+3 is offline   Reply With Quote
Old 07-22-2014, 01:59 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
Only ones I've seen it in is those custom conversion trucks with the extended cabs done on them. The seats are not factory nor is the big console that goes front to back.
I'm sure what you're talking about has been done a few dozen times. Four doors, four seats. Perfect sense.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 07-22-2014, 11:11 PM   #5
mrolds88
I do not see why it wouldn't work. Back seats are the same as a standard cab truck. If they are Suburban seats, you'll have to modify the rear of the slides as many have done when putting them into a standard cab. As far as the console, I don't see a problem there either.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-22-2014, 11:34 PM   #6
spgill2000
Thumbs up Re: Front buckets w/console in rear of 73-87 crewcab?
Thanks for the info....guess im fabbing!
I was expecting that...I was just curious to see if anyone had factory bracket swap tips to make this more of an exact(ish) fit!
Old 07-23-2014, 12:35 AM   #7
1968vetL-71
Junior Member
1968vetL-71's Avatar
I would think the outer brackets would bolt up just like the bench seat in the back, then maybe you might be able to just find another set of rear brackets for the inner rails. I'm getting ready to do the carpet, doors and headliner in my crew so I might put the rear brackets on my buckets and see if it will work. Be next week before I'll get a chance too.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 07-23-2014, 08:49 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
depending on the pic,burbs insides can look like a crew
different floors etc tho,here are some conversion seats
watch for thin seat tubes,on custom seats mine kept breaking
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-23-2014, 09:43 PM   #9
spgill2000
Thanks for the info guys! I'm gonna put the four factory front burb buckets and pair of consoles I dug up in the 'ol '79 crewcab. I like the "should'a been built this way" look. Factory period correct parts that fit and look better than what was available seems like a no brainer.
Old 07-24-2014, 08:53 AM   #10
truckfan
truckfan's Avatar
i would think factory bucket brackets from a regular cab would fit the rears in a crew due to the fuel tank hump.
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
