07-22-2014, 02:20 AM | #1 |
Converting 4x4 to 2wd, what needs to be done?
What all is involved in converting a 4x4 to a 2wd? I gotta 2wd crossmember, what else do I need to get or is all bolt in? Any threads on any of this? Any help would be appreciated
07-22-2014, 02:39 AM | #2 |
Re: Converting 4x4 to 2wd, what needs to be done?
I would sell it and buy a 2wd truck,The 4x4 is worth more you can sell it buy a 2wd and have cash left.To do the swap you need the whole from front suspension from spindles to steering box.The rear im not sure on might just be the springs other things will be changing out the trans and new rear driveshaft.
07-22-2014, 03:16 AM | #3 |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
07-22-2014, 05:07 AM | #4 |
KQQL IT actually hit the nail on the head as to what I wanna do. Im going to be building a blazer roadster and 2wd blazers are rare here and can pick up a 4x4 for fairly cheap. Im also in the middle of swappin my longbed to a shorty, unfortunatly the longbed frame is badly damaged so I cant use the front clip. Otherwise id just go get some steel and build a frame.
07-22-2014, 12:25 PM | #5 |
At the body shop.
Frame is the same. Just swap the x member
07-22-2014, 02:05 PM | #6 |
Yup! For the rear, you'll need 2wd spring hangers as well. The 4x4 ones are taller.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
07-22-2014, 04:43 PM | #7 |
There are other options that require less work. The 2wd hangers can set the rear lower than the front depending on which springs you use.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
07-22-2014, 09:25 PM | #8 |
I swapped my 4x4 k5 to 2wd as well. Flip kit in rear with 4x4 mounts still
You need to cut the rear bump stops out unbolt the front suspension and the cut every rivet there is up front pretty much. Measure off of the 2wd doner or another truck and place the crossmember in that position drill the holes and bolt it up then do the same with the front crossmember. Then measure and drill for the suspension linkage and swap the steering box to a 2wd version. That's about it in a nutshell. It's time consuming but not so difficult unless you haven't got the right tools. I borrowed a plasma cutter and gouged the rivets off. Easily the fastest way to do this.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 Last edited by INSIDIOUS '86; 07-22-2014 at 09:31 PM. Reason: Thor killed some ice giants |
07-22-2014, 10:46 PM | #9 |
Oh its gonna be bagged and bodied guys
