Blazerless:-(
Installing new tach gauge in a non-tach dash cluster?
I would like to insert a tach gauge into my existing dash cluster, Does anyone know what that involves? I have my dash out already and a limited amount of $$$. My dash cluster is in good shape and has a new bezel. Also can I change the mileage on my odometer? I just put in a new engine and would like it to reflect my new mileage. Is that legal??
![]() Join Date: Jan 2002
You will have to get a new printed circuit. Th ones for a tach dash are designed to have something in the middle hole. Yhey will fit around an aftermarket tach. You will have to do alittle bit of cutting on the other parts of your dash assy. As far asresetting your odometer, If you are never planning on selling your truck it probably wont hurt. Alot of guys reset theirs when they put a new engine in. I imagine it is probably illegal in most states. You would probably have to check with your local MVD.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
It is not hard to install into a dash gauge cluster. You will need (6)
things in order to change it out. Kits are available. You will need the following items: Tach New face Reveal The sheet metal housing Tach wiring Tach printed circuit You can use your existing bezel if it is for a gauge cluster. Jim |
We have the tach conversion kits for 229.00 in our catalog or can get you each piece seperate.
Rest in Peace Ed. Thanks for all the good times. |
Are you looking to install an "oem" tach or an aftermarket tach?
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
Pronounced "Pew-al-up"
I installed an aftermarket Tach in mine, without buying anything,
I just soldered in jumper wires for the printed circuit board, and used my Dremel to cut out the hole!! ![]()
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
David Tye
hey Dano, could you post a pic of that? im thinking about doing the same thing
David -68 GMC w/327 |
Yeah I'll try to take some photos tomorrow!!!
![]() It was pretty easy to do, and I didnt want to spend alot on the project. I bought the tach on e-bay for $19.95. ![]()
Low & Slow
Hey dano, I didn't even have to make jumper wires for mine. I just cut the little hump out of the back plate with a cut out wheel and ran the tach wires through it. I butted the back of the tach up to the back plate. I do have about an 1/8 of an inch gap between the tach trim ring and the dash bezel.
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
Blazerless:-(
Miket- I'm not sure if I want an aftermarket or OEM. My blazer is going to be pretty stock, but some custom things in the interior- so it doesn't have to be OEM.
DanoDMano- I'd like to see pics too! ![]() |
70Blazin,
Here is a pic of a "Sun" Tach that I picked up fairly cheap and installed in a day.
David Tye
wow, that turned out nice!
#13 |
Its Magically Delicious
miket ....what model number is that sunpro tach??? .... looks really good ...i'd love to do the same .... feel free to pm me with instruction ...thanks
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
#14 |
WHYBYNU when old will do?
miket,
I'd also like some more info on that tach. Please post it here or send me a PM.
-72 Chevy C10 Stepside -2002 Chevy Silverado 2500HD 4x4 -1984 Jeep CJ7 -1995 Polaris XCR600 Custom -2003 Honda 300ex |
#15 |
Okay guys, it's a Sun Tach with Shift light ...I will get you the actual part number tomorrow...it is available from summit as a Summit branded product....it is also available from (those of you who live in the Pacific NW) GI Joes....thats where I got mine...stay tuned.
#16 |
Here is a link to the Sunpro site and the specific model I bought....for those of you with White guage faces....they do offer a white tach.....don't pay the web price.....you can get these much cheaper elsewhere....
http://www.actron.com/cgi-bin/web_st...d=5372924_5431 It was easy to install....obviously remove the entire bezel from the truck and disassemble it...I cut the acrylic out with a dremel tool and cut off wheel...I also cut the metal housing behind it...wiring was simple...ignition/lights/ground and distributor feed. It fits flush in the bezel though I used a large hose clamp around the housing inside the bezel to secure it firmly (friction fit) in the bezel opening. hope that helps...PM me if you have any questions.
#17 |
Here's mine
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
#18 |
I am sorry I havent posted tach photos yet...
![]() I am installing the A1 electric door locks and havent been able to get my bezel off. I will do it today and then post them when I get to work at 3:00 PST. Sorry... Dan ![]()
#19 |
Here is a couple pictures of my Tach, and Printed Circuit Board jumpered.
#20 |
Another from the front.
#21 |
DanoDMano,
That cluster looks pretty sweet! What brand and type of Tach is that? (Sorry if you already answered that, just point me to it if you have).
#22 |
Here is a link. I bought it on e-bay for $19.95.http://www.egauges.com/vdo_mult.asp?...t_Royale&Cart=
#23 |
Sweet, looks like you got a great deal!
#24 |
another of mine
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
#25 |
miket..is that sunpro a 3 3/8 or 3 1/2 diameter??
thanks
