07-22-2014, 02:42 PM | #1 |
65 Motor Swap
So i picked up a real nice 65 LWB custom cab and BBW truck. (Pictures to follow). It has a 350 and manual tranny on the column shift. The motor has no intake manifold or valve covers and i dont know how long it has been sitting but the last signs of life I found was a 1985 sticker. So I pulled the motor out and when i pulled the oil drain plug i filled up an entire oil drain pan with WATER! No oil came out. I have another 350 that is ready to go so i plan on dropping it in. I want to check the condition of the 3 speed before I bolt it up to my other 350. I don't really wanna take it to a shop. The shifter linkages on the tranny do not shift freely. Also, the truck has a crossmember that runs just below the tailshaft of the transmission but it was not bolted to it nor resting on the member. I will get some pics up here this evening. Thanks Yall.
Active duty Navy CPO 1961 C10 SWB 1963 C10 LWB (donor) 1965 C10 LWB BBW |
07-22-2014, 03:25 PM | #2 |
Re: 65 Motor Swap
If the crossmember isn't for the tailshaft mount, its probably the ebrake crossmember. Pics will help identify it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-23-2014, 12:12 AM | #3 |
60-66 Nut
Re: 65 Motor Swap
I agree ^^^^
If the truck still has the original bellhousing and it's acompanying crossmember, you do not need one at the rear of the trans.
