which way does the heater fan turn looking at the shaft end CW or CCW? no luck in elect. forum. Randy
Re: heater fan
If you are looking at the end that the blower fan mounts to, I think it turns counter clock wise. The lovers on the fan should give you an idea. I had the same concern so I installed the blower in the case and hooked up power. It blew air the wrong way so I just reversed power and ground
