07-22-2014, 04:11 PM | #1 |
Let's drop another 67 short bed
Good afternoon guys.
I trust the guidance of these forums as these boards have always pointed me in the right dirrection. 67 short bed with leafs in the rear. I will stay away from lowering blocks and notching the frame. I don't mind spending money to do it right, but it's always nice to go cheap when it's done right. What kit's do you like for the money and ride quality? I am looking for aprox a 3" drop up front and 5 in the back. I'd like more, but for now I want to keep my long tube's. Thank you in advance, here is what we are up against. |
07-22-2014, 06:56 PM | #2 |
Re: Let's drop another 67 short bed
Thoughts?
07-22-2014, 09:20 PM | #3 |
Forgot to mention. I have disks in the front.
Reading a little more I would consider a 4/6inch as long as a notch isn't required. |
07-22-2014, 09:25 PM | #4 |
I'd go with a 4/6 drop instead, but most say you will require a c notch if you go that low. Also an adjustable track bar,
07-22-2014, 09:26 PM | #5 |
Ece?
07-22-2014, 11:00 PM | #6 |
ECE has 4" drop leafs and you can add their 1.5" lowering shackles for a total of 5.5"
'68 SWB Fleetside '98 K1500 Silverado |
07-22-2014, 11:11 PM | #7 |
i say don't drop it i think it has a way cool stance the way it is don't forget its a American truck keep it a truck just my opinion too many taco hauler c10's in this world already starting to forget what a truck is
07-22-2014, 11:13 PM | #8 |
I just ordered a power disc/ 2/4 drop kit from CPP. They told me that 3/5, which I had ordered originally, would require a c notch. I was bummed when they told me that.
07-22-2014, 11:15 PM | #9 |
I disagree. His truck looks like a 4x4. A nice drop on a 2wd truck looks so much better imho.
07-22-2014, 11:15 PM | #10 | |
This truck is a legitimate "taco hauler" as you so eloquently put it. Haha, I'll take the compliment though. My other trucks are 4x4 however. Modified suzuki samurai and a fj cruiser. I use trucks here in the rockies |
07-22-2014, 11:20 PM | #11 |
Any opinions or users of the djm kits?
http://djmsuspension.com/products/djm-19/ |
07-22-2014, 11:26 PM | #12 | |
07-22-2014, 11:29 PM | #13 |
I hear ya brother. Haha
Thank you guys for the help by the way. I appreciate it. |
07-22-2014, 11:34 PM | #14 |
I have the DJM flip. Nicely done kit. I didn't notch and only bottom out occasionally. You do have to move the shock mounts so the shocks are more upright.
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
07-22-2014, 11:38 PM | #15 |
on another note i see your truck is hot rod black did you color sand it or does the paint have some texture to it just asking cause mine is the same and i have being sanding it to make it smooth but not sure if its a good idea im at 800grit now going to 1500grit next go around to smooth out the scratches
btw thats the stripes i plan to do lace work to |
07-22-2014, 11:40 PM | #16 |
07-22-2014, 11:43 PM | #17 | |
07-23-2014, 08:11 AM | #18 |
Nice lookin truck. From the pics it looks like you might run into a header issue if ya a go too low.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
07-23-2014, 09:33 AM | #19 |
"taco hauler" That's funny!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
07-23-2014, 09:34 AM | #20 |
Oh yes, BTW. It's your truck, make it how you want it!!!
07-23-2014, 12:02 PM | #21 |
I just drilled out the second hole in the shock mount bracket with a step bit and used the stud that came with the replacement Monroe shocks. I had to get a bolt that threaded all the way down and some lock washers from the local ACE hardware, the bolt that came with the shocks didn't thread far enough down. I used the stock front size in the rear as 'drop shocks' and they seem ok...might actually measure one day.
http://67-72chevytrucks.com/vboard/s...d.php?t=577529
07-23-2014, 03:54 PM | #22 |
Alright. Almost there, I'd like to post up my thought process for any future rear leafers as the information is scattered online.
I called Early Classic Suspenion and figured out most of the set up. For now I will run a 5.5 drop from ECE in the rear. This is 4.5 leaf drop and 1" leaf shackle drop. http://www.earlyclassic.com/catalog....gory=New+Items I like the idea of getting new leaf packs the accomplish the drop. I was really wanting to flip the leafs under the axle, however this is going to be an aprox 7" drop and require holes to be drilled for the shocks. For anyone interested in a axle flip, DJM sells a kit. I am going to run a 2.5" drop spindle and 1-1.5" lowering coil spring up front with new shocks all around. There really is no other way as I belive just drop springs will be too harsh on the ride. http://www.earlyclassic.com/catalog....gory=New+Items Aprox. $1000 shipped. I don't think that I need to notch with the drop leafs @ 5.5" and I can always go lower with a block if I do decide to notch one day. I need to make a few more measurements before ordering, I should have this sorted out to order over the weekend. lol I measured about 7inches in clearance from the long tube header to the ground. I'll run it for now and adjust later to get my perfect stance with an old school rim/tire combo. (not sure what I want yet) 15's? |
07-23-2014, 07:13 PM | #23 | |
1970 C10 Short Stepper with 71/72 front clip. |
07-23-2014, 07:30 PM | #24 |
"I like the idea of getting new leaf packs the accomplish the drop.
I was really wanting to flip the leafs under the axle, however this is going to be an aprox 7" drop and require holes to be drilled for the shocks. For anyone interested in a axle flip, DJM sells a kit. I am going to run a 2.5" drop spindle and 1-1.5" lowering coil spring up front with new shocks all around. There really is no other way as I believe just drop springs will be too harsh on the ride." You will most likely still need to drill the holes to relocate the shocks just because of the geometry change...no biggie as that was probably the easiest part of the whole drop. New leafs are never a bad idea as the bushings are all new as well. I have the 2.5" spindle 1" spring combo and you don't need drop shocks for it as the geometry remain relatively the same. Make sure you have at least two sets of jack stands for frame and axle, a floor jack, and at least one other jack to help 'nudge' stuff into position.
07-23-2014, 08:03 PM | #25 |
67-72 parts collector,…
What year spindles are on your truck now?
