My first new old chevy
Hello guys so I just bought my first old new truck. This is my baby and I have a ton of plans for her. I also have a lot to ask cause I never had something like this to work on before. I am in the navy and have been stationed in Norfolk va. I bought the truck from a guy a little bit north of here she is clean no rust underneath. He did most of the work to the truck Like
Original engine was a 283, new motor dropped in at 72545. New motor came out of a 74 camaro. Motor- 350 2 bolt main. Bored .30 over, mains and rod bearings standard. 4 dish flat top pistons Heads- Are a 462 cast 58cc chambered double hump 1958-About 1962 corvettes, (furie heads) with screw in studs, posi loc rocker arms nuts with high performance valve steam seals. Cam- Comp cam 272 Intake- Edlebrock performer Carb- Edlebrock 650 1st gen- AEI distributor, after market with vacuum ADV Rear end- 1974 chevelle, has new seals and fresh lube spark plugs- are ap 85's (auto lite) or equvilant plug wires- 8mm Tranny- Is siginaw 35pd manual Ignition modual- BWD CBE4P This is some of he work he did on this truck and I plan on doing much more. Now I am trying to change the front drum breaks to disc and power breaks all the way around. The guy I bought it from had a set of 74 chevelle spindles that he had bored to fit the original ball joints and tie rod ends. I am trying to make this work so I can keep the spindles, and rims that are already on the back. Some of the guys at napa have been helping me out but I would like some help from the pro's (you guys). The guys at napa have been hooking me up with 69 el camino rotors and calipers because they said that is what will work with the spindles that I have been given. I also really don't know what kind and where I should pull the break booster and master cylinder off of. Or should I just order one? Also if there is a need for a bracket to mount to the fire wall. Also what about a proportioning valve? Thanks guys for helping me out with this I really appreciate this. |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: My first new old chevy
Looks like a solid truck.
Since you're new, I'll recommend you to take care of that floor mat. It looks to be in nice shape. Welcome to the Forums.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#3 | |
Browse through here:
http://67-72chevytrucks.com/vboard/s...d.php?t=559678 . But feel free to ask questions. So many good kind helpful members here. . Yes, the Discbrake upgrade is a great first project.
Thank you this is really helpful I will read up on it and I will get back to you probably with a ton of questions too.
![]() Join Date: May 2007
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Post Whore
![]() Join Date: Mar 2013
Welcome aboard! Sweet ride!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Welcome to the forum
![]() ![]() Looks like you have a truck with a good start. I do sell booster brackets that are bolt on with no need to drill holes. There are links to most of my products in my signature line \/ \/ \/ Service members and Veterans get free shipping. Another little tip....I would get rid of that plastic fuel filter and re-route that fuel line around the front of the engine like it should be with as much steel line as possible. That fuel line setup is a disaster waiting to happen sitting above the exhaust like that.
Thank you all very much its really appreciated!! Captainfab thanks for the advice. Should I keep the filter and reroute the gas line in front like you said?? Also where should the line run?? Would you have any pictures by chance so I have something to reference? I will get right on that and get back to you thank you. A couple quick questions about the setup I am trying to accomplish. Now will any break booster and master cylinder work on this truck or is there a specific one I should be looking for?? Thank you guys very much for the warm welcome and great knowledge.
Who Me?
Welcome!! Looks like you off to a great start!!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
