Old 08-06-2003, 08:18 PM   #1
brad20653
electric door open help
I have shaved doors now i need that electric thing is it hard to put in ? Is it expensive to just have someone do it ?
Soon to have 68 SWB 350 with Turbo350
brad20653 is offline   Reply With Quote
Old 08-06-2003, 08:48 PM   #2
jef5150
Inline 69
jef5150's Avatar
heres the kit...............
http://www.a1electric.com/Merchant2/...Code=POP-R2SOL $149.00,,,,,,,,
jef5150 is offline   Reply With Quote
Old 08-06-2003, 08:58 PM   #3
brad20653
What do u think it would cost to have that installed if i bought it ?
Old 08-06-2003, 09:03 PM   #4
chevykid1969
chevykid1969's Avatar
I bought that exact kit and started instaling it last weekend. It is so easy. The hardest thing is running the wires through the door, which i still have not figured out yet. Anybody have any ideas. To answer your question it would probaly cost alot just because it takes some time to make sure everything opens right.
chevykid1969 is offline   Reply With Quote
Old 08-06-2003, 09:04 PM   #5
brad20653
You think you could write up some tips that u did or step by step instructions please ?? What do u do if the battery dies or the remote breaks ?
Old 08-06-2003, 09:17 PM   #6
chevykid1969
Sure
Sure Ill also take some picks tommrow. If you have shaved your door handles go ahead and take out the door hardware so you can get to everything. you can eliminate the part that locks just take a drill and drill out the rivit and toss it you want need it any more. drill a 3/16 in hole in the lever that rotates down and you can put your cable there with the hardware supplied with kit. place the solenoid in the end of the door near the bottom right under the door latch. it is very important to make sure your door opens and closes without any dragging so not too put any stress on your solenoids. you can place your poppers where the rubber bump stop is now, just drill out the hole to match. you will have too do a little forming on the edges of the poppers for best fit. hope this helps good luck. I dont rember who i got the inst. from but thanks. Also you can buy a kit that riggs a wire to the lever so if your batt. dies you can pull it and it will open the door. But for mine i have a place i can hook another 12v sorce to and open the door. Ill post some pics tommrow of the popper location and see if i can get some other shots. If you have any ohter questions just send me a PM.
Old 08-07-2003, 09:25 AM   #7
smokekiki
Mike
smokekiki's Avatar
Has anyone checked out the kit from www.customclassic.com $$$ but has new latches with solenoids attatched.Click on ultra on there site.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-07-2003, 10:33 AM   #8
jays68yak
jays68yak's Avatar
I saw a cool setup that uses stainless steel springs to run the wires through and then is held in on one side and slides in and out of the other. I saw it at a show, and then last night when i was going through a magazine. Ill see if I can find it again.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 08-07-2003, 12:13 PM   #9
Earl Junior
Cadillac power
Earl Junior's Avatar
I ran the wires for mine underneath the flat stop bar (I guess that is what it is) that goes between the door and the cab. I used a dab of clear silicone to hold the wires in place.
If that makes no sense, let me know and I'll try to get over to the storage shed and snap some pics.
Custom Classics makes a wireless adapter to run the wires into the door. Here. I'm pretty sure I've seen the same thing in JC Whitney and at the local stereo store.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style.
--Scott Adams author of Dilbert
Earl Junior is offline   Reply With Quote
Old 08-07-2003, 05:16 PM   #10
chevykid1969
Pictures
Ok here are some pics. I finally got it all wired up to day. (man grounds can be a pain in the A$$.) But everything worked out great. If you have anymore questions or need better pics just PM me.
Old 08-07-2003, 05:18 PM   #11
chevykid1969
Popper
Popper
Old 08-07-2003, 06:30 PM   #12
Chevy_68
Chevy_68's Avatar
KOOL TIPS THIS IS HELPING ME SINCE IM ABOUT TO ORDER MY KIT MY QUESTIN IS WHAT ARE THOSE BLOCK LITTLE BOXES W/YELLOW BUTTONS OR SOMETHING WHAT DO THEY DO
Chevy_68 is offline   Reply With Quote
Old 08-07-2003, 07:40 PM   #13
chevykid1969
The ones that i got say trunk on them so i guess you use them if you have a trunk release too, but i mounted mine on the inside of my cab so i can open the doors at the push of a button. Ill take some pics tommrow.( i am painting the buttons red to match my interior. IMO if i did it again i would not use the buttons. it just made wiring everything up alot harder. any other questions
Old 08-07-2003, 07:46 PM   #14
tim m
Check with RB Obsolete, I bought a wire loom set up from them that is like a Stainless spring that is held on one side of the frame and slidesinto the door on the other. It is the best setup I have seen. I can't remmember who else had it I think it was low68.
1970 k10
1971 C10
Gilbert Az
tim m is offline   Reply With Quote
Old 08-07-2003, 10:27 PM   #15
jays68yak
jays68yak's Avatar
http://www.sachserodshop.com/pdf/137.pdf
5th one down if i remember correctly.
