Old 07-22-2014, 09:02 PM   #1
67chevy_hotrod
67chevy_hotrod's Avatar
More Engine Codes!
This is annoying. So SS Tim I believe his name is helped me with my last code debacle, this time nothing is the same. Its a 283 at least has the valve covers and oil filler tube of a 283 but we dont know the year i pulled the code off of the deck and it is FO3I3D and that is the only thing on the deck.. anybody please?
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 07-22-2014, 09:16 PM   #2
john
member #16
john's Avatar
Re: More Engine Codes!
http://www.nastyz28.com/gm-chevy-cod...s-suffix-4.php
john is offline   Reply With Quote
Old 07-22-2014, 09:26 PM   #3
bruceman1968
bruceman1968's Avatar
F = Flint (Motor)
03 = March
13 = 13th day (the I is a 1, I'm sure it's a I on your block but Is got used as 1s often. There is no letter that belongs in that slot.)
D = 55 265 Truck 205 manual 4bbl
D = 56 265 Truck 205 manual 4bbl
D = 58 283 Impala 185 PG 2bbl
D = 59 283 Impala 185 PG 2bbl
D = 60 283 Impala 170 PG 2bbl
D = 61 283 Impala 170 PG 2bbl
D = 62 283 Impala 170 PG 2bbl
D = 63 283 Impala 195 PG 2bbl
D = 64 283 Impala 195 PG 2bbl
Check the date code on the block for the year.
bruceman1968 is offline   Reply With Quote
Old 07-22-2014, 09:44 PM   #4
67chevy_hotrod
Thanks Guys! I suppose this is as specific as it gets then? Dont get me wrong i appreciate the help! But i wish there was a way to tell exactly what it was from originaly I am getting another 283 soon to build.
1967 Chevy CST 10
1969 K10 Suburban
Old 07-22-2014, 10:05 PM   #5
bruceman1968
There is, just get the date code off the block. Or are you meaning more specific than that?
Old 07-23-2014, 04:14 AM   #6
SS Tim
SS Tim's Avatar
You have the plant, engine assembly date and a "D" application code. For more you are going to need the block casting date/year. This going to give you the source installation like Bruceman1968 shows. With a March date code the model year is easy to deduce.
Cross check the block casting number to verify the application.
Then see what the head casting number and date codes are.
If you want more check intake casting and date code.
Even a distributor is coded.
Its not rocket science just a matter of digging, recovering the numbers and seeing how well they fit to determine what you have and what it might have been.
SS Tim is offline   Reply With Quote
