Lowering block /perch width
I have a 53 1/2 ton gmc with 1 3/4 in.wide rear leaf springs .I am installing a 68 tempest 3 in. diameter rear. I want to use 2 in. drop lowering blocks and new perches. What width do I need for the perches and lowering blocks. Do they have to be the same width. I see them in 2, 2 1/4 Is it that important?
Re: Lowering block /perch width
I've got lowering blocks / perches made out of 2x4 1/8" wall square tubing. They are welded to a 12 bolt axle out of a c10 mounted to the stock springs. The blocks are only 1/8" wider each side than the spring and I've had no problems. Just Use the right size u bolts and make good strong mounting plates for under the springs and you should be good to go
Thanks for info
you want the perches and the blocks the same width as the springs,
you want to mount the ubolts straight and tight up against the blocks and springs, i found 1-3/4" perches at a 4wheel drive /Jeep Shop. i found 2 pieces of aluminum on ebay 1-3/4 by 2" |
