07-22-2014, 09:57 PM | #1 |
2WD Lift kit ?
Is there anyone out there lifting 2 wheel drive suspensions on these older trucks? I've seen it done on some newer ones to look like off road racers (prerunners I've heard them called), but I have not seen it done to a '67 C10.
I realize that everyone has their own vision of what a truck should look like, and that's cool. It does seem like all the 4x4's are lifted and all the 2WD's are dropped to the ground. I'd like to see my 2WD C10 sit up just a little, maybe 2 inches or so above stock, and some taller tires along with that. I can't be the first to want this, right? To be clear, I'm not talking about big, crazy modifications, or some sick desert racer. Anyway, here's my question: Are there any parts available to do this? |
07-22-2014, 11:01 PM | #2 |
Re: 2WD Lift kit ?
short answer: nope
but you can get springs for a heavy duty big block C30 to lift the front end up a couple inches. (more than that if you are on 40 year old springs now) And shackles or blocks in the rear end. Other than that its custom.. |
07-23-2014, 10:45 PM | #3 |
Re: 2WD Lift kit ?
I like your idea of bigger springs. I was going to put fresh coils under all four corners, anyway. I wonder if longer springs exist without a heavier spring rate. I don't really want a rough ride. Blocking up the springs might also be a possibility. Blocking up the body might also work.
Looking at 2WD lift kits for other trucks, I've seen both extended springs and coil spacers. Rough Country offers these for 2WD Chevys 1988 and newer. I am inclined to believe coil spacers could work on my '67 C10. Might the Rough Country spacers fit? If not, maybe I could fabricate some. Can big tall springs made for some other application, possibly be cut down to fit? Air bags? Just trying to think outside the box |
07-24-2014, 12:38 AM | #4 |
Re: 2WD Lift kit ?
With coils your easiest route will be the coil spacers. If I remember right folks run tj wra gler springs to lower. If have to see if I could run their spacers above your coils
07-24-2014, 01:34 AM | #5 |
Re: 2WD Lift kit ?
Perhaps maybe you should look at lift spindles as well?? Dino on here lifted his 60-66 2wd...
07-24-2014, 04:45 AM | #6 |
Re: 2WD Lift kit ?
When they stopped making 7.00 x 17.5 LT bias ply tires, and I had to 'jump up' to 8.00 x 17.5 on the OED [SPID noted] 17.5 x 5.25 Rims --I found I had an extra inch of "Lift". Bigger tires with more circumferance were cooler. My speedo was off- true , but I liked the increased torque. Beefier shocks completed the "Lift Kit". I remember my mechanic gave me a catalog for a crash part company, and there were all manner of silicon/polyurethane spacers to shim up springs, also stiffer or taller spring coils for sale.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-24-2014 at 02:17 PM. |
07-24-2014, 08:45 AM | #7 |
Roto Reuter thats the name...
Re: 2WD Lift kit ?
When I did front disc conversion on my C20 I changed out the front springs. I installed some HD springs (P/N 2772074) bought from NAPA. Tires do not rub at all. They are 285/70-17 tires with H2 Hummer wheels. The ride is somewhat stiff, but hey it's a 3/4 ton truck. Here's a comparison of the springs:
The stock HD C20 springs are as follows: http://www.napaonline.com/Catalog/Ca...752_0162319756 Part No.: 2771752 No. of Coils: 7.92 Free Height: 12.94" Spring ID: 3.68" Spring Load Height: 10" Design Load: 2950 Spring Rate: 1016 Wire Diameter: 0.812" The springs I put on from C10, C20, C30 from 1973-83. They are as follows: http://www.napaonline.com/Catalog/Ca...074_0162301536 Part No.: 2772074 No. of Coils: 8 Free Height: 13.61" Spring ID: 3.676" Spring Load Height: 10" Design Load: 3841 Spring Rate: 1060 Wire Diameter: 0.83" You could also use C30 mid '80's 1-ton springs, but I thought they would be too stiff. Those are: http://www.napaonline.com/Catalog/Ca...085_0162304063 Part No.: 2773085 No. of Coils: 7.93 Free Height: 13.34" Spring ID: 3.65" Spring Load Height: 11" Design Load: 3289 Spring Rate: 1318 Wire Diameter: 0.906" My other truck is a '70 K10 with a Skyjacker 2-1/2" lift using new leaf springs all the way around. I hope this helps.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
07-24-2014, 02:19 PM | #8 |
Re: 2WD Lift kit ?
I recently saw a thread in the FAQ section about "easy disk brake swap" and it had some interesting info which leads me to believe there is a way. Two members had successfully swapped 88 & 90 spindles, rotors, brakes, ect. directly onto their stock arms. In theory you may be able to use lift spindles for a 88up if you are willing to do the work.
10-27-2014, 03:12 PM | #9 | |
Re: 2WD Lift kit ?
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
10-27-2014, 06:33 PM | #10 |
Re: 2WD Lift kit ?
I never got around to changing the rear springs. They're probably just older original (stock) C20 springs.
