70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Installing Mahanians' Billet Aluminum Radio Plate
This is a pretty simple install, cause even I pulled it off. My one suggestion is to make sure the stereo goes in through the plate properly especially if you are getting a shop ( like I did ) to install the stereo. My dash was cut by the PO so this was a great solution for me. Jareds' instructions are very good the only thing I changed was I drilled ( with a tiny bit ) a guide hole through the template paper, then removed the template and drilled the holes to the right size.
Here is what I had when I removed the 90's C/D player when it croaked. I taped the template over the hole. After the holes are drilled The Polished Billet Aluminum Plate Installed The new Sony installed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 07-23-2014 at 11:58 AM. |
Re: Installing Mahanians' Billet Aluminum Radio Plate
Great look, I need to do this.
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
The Older Generation
Good job on the install... Looks great! LockDoc
How much are those billet plates? That looks really nice!
![]() Join Date: Jul 2010
That looks great. I need to do the same thing. I wasn't sure what I was going to use. Thanks for sharing. Do you have a link?
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
![]() Join Date: Jun 2012
That turned out really nice
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
Thaaaaat- is tight! I did something similar in a 72 Monte I had, looked factory. Great stuff!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
That looks good enough to make me want to cut my dash in my truck......even the el camino
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Great job! Am I correct in assuming there are studs /bolts/screws attaching these plates?
Just curious, I'm going to do this as well. Thanks! Ben |
You are correct and they are included with the plate along with a polishing cloth. here is a pic of the install instructions.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Hello my name kelvin, how do i go about ordering a billet radio bezel i cut my radio dash hole to wide.
#13 |
Hello my name kelvin, how do i go about ordering a billet radio bezel i cut my radio dash hole to wide.[/QUOTE]
#14 |
hers a link to the thread for purchasing the bezels.
http://67-72chevytrucks.com/vboard/s...d.php?t=654607
