Old 07-23-2014, 04:05 PM   #1
Nola67
under bed tank options
I know there are several.. from no limits, boyds to cpp and blazer tanks so on.
Would you guys that have a ls friendly under bed tank mind posting up your set ups?
daunting to search all the build threads.. be nice to have a one stop shop for info on all the different options..
Nola67 is offline   Reply With Quote
Old 07-23-2014, 06:47 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: under bed tank options
Fabbed aluminum 16gal fuel cell. Has a few sq feet of tank foam in it, and a sumped bottom where my fuel feed line is.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-23-2014, 09:36 PM   #3
Blackpony
Blackpony's Avatar
I am running a 91 suburban tank. Just installed a high pressure 255 pump and got a couple of adapter to hook up an lines. Had to fab up some brackets to mount it but that was easy.
Blackpony is offline   Reply With Quote
Old 07-24-2014, 10:02 AM   #4
Nola67
Cool work br3w city. Does the fuel line have potential getting caught on something going down the road or is that just the pic?
Black pony, whats the measuments on the tank? Price? Any ground clearance concerns? Seems like a decent alternative to a 800$ aftermarket tank..
Old 07-24-2014, 12:08 PM   #5
littlevictories
i used a spectra tank from a '69 camaro ( kinda funny that so many parts meant for that car ended up on my truck, friggin hate those cars)
I can't find any final pics but here's a link to my flickr which has some shots of it going in https://www.flickr.com/photos/lammergeier/11957948316/
I'd probably do it different if I did it again. maybe a blazer tank or a adapt a 99-2003 silverado tank into a left side saddle tank.
It's a hard fill for the pump jockeys (oregon law, can't pump your own freedom juice) and they usually spill some.
littlevictories is offline   Reply With Quote
Old 07-24-2014, 01:35 PM   #6
66LSx
66LSx's Avatar
Boyd.... rea$onable priced even with the Aeromotive Stealth 340 in-tank pump (and should be quieter too)
And it just looks professional. Top notch quality... here is the one I put in my 66 (its actually a 67-72 EFI Bed Fill tank that 'fits' into our 66 C-10's....
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 07-24-2014, 01:38 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The line sits more even with the tank strap than it looks in the picture. It doesn't hang below the tank, it only protrudes slightly to the side. If you drew a straight line from it, there are about 3 things that would hit before the actual line caught on anything.
I guess if I ran over a bunch of rebar or something it could, but its pretty unlikely to say the least. It also makes pumping the tank down easier...my fuel pump comes off the frame rail, you can drop into a bucket and power-pump the tank empty.
Old 07-24-2014, 09:03 PM   #8
Blackpony
Blackpony's Avatar
The tank is huge, its 31 gallons. I just ordered the tank and hanger assembly from ebay. Got the part numbers off oreillys website and put them in the search. I believe all said and done I have around $250 in it all. The fuel pump i actually got for free. I work at a performance shop and we had a bunch of factory 5.0 mustang fuel pumps laying around so i cut out the pump itself and installed it. Those cars run around 55 lbs of fuel pressure so it should be fine. I have also made over 600 rwhp using the stock pump without a boost a pump so I will be fine there. I will try and get a few more pictures, but with the way I fabbed my hitch it barely fits but it fits. Also one thing to note is the filler neck will need to be relocated. Lastly ground clearance should be around 10-11 inches at the lowest point. The tank has a notch at the rear that helps with clearance also. Hope this helps, my swap is not a simple bolt it in, some fab work will be needed, but all said and done it will be at least half the price as most other aftermarket tanks.
Old 07-25-2014, 12:11 AM   #9
littlevictories
@66LSx dude you are killing me with that single reservoir master cylinder!
Old 07-25-2014, 06:58 AM   #10
66LSx
66LSx's Avatar
patience.... its getting a dual pot w/ a booster
1966 C10 SWB Fleet
Old 07-25-2014, 09:06 AM   #11
Custom 68
Custom 68's Avatar
I used a poly Blazer tank with an external pump for a few years. I wanted a better looking and working system so I went with boyds with an in tank pump. I am happy with it.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-25-2014, 09:09 AM   #12
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I also did the Boyd's tank, It was reasonable but mine has external pump since I had it prior to the tank.
Hey Brew, Your arse is showing!!!!! cover that thing up dude!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-25-2014, 12:47 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Gotta give people behind me something to aim for....with all that crash resistance a roll-pan has
Old 07-26-2014, 06:56 PM   #14
Clyde65
Clyde65's Avatar
Hahaha! Hopefully they have bad aim and miss you and your truck completely!!!
Clyde65
Rebuild of Clyde
support our troops!
Old 07-28-2014, 09:34 AM   #15
Low Elco
91 Jeep Wrangler tank. Like it grew there. Search the Silver Dollar thread.
Low Elco is offline   Reply With Quote
Old 01-09-2015, 01:23 AM   #16
Gooker928
i also used this tank. It's the most natural looking of any ones I've seen.
Gooker928 is offline   Reply With Quote
