Old 07-23-2014, 08:08 PM   #1
FlameOut
Need photo of swb 4x4 frame
This might sound like a dumb request, but I couldn't find any frames looking through the build forum. Reason I ask is I wonder if I am missing a cross piece on the rear of my frame. My frame is pretty bad, but I repaired it with new metal, but want to be sure I don't need to do more repairs.
This is it when I bought the truck and after repaired and then primed
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 07-23-2014, 08:15 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Need photo of swb 4x4 frame
Yes, you are missing the rear cross member. Should be about 3-4 inches or so from back frame tip. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 07-23-2014, 10:36 PM   #3
FlameOut
Ok, thanks. I have some 2x2 square tubing so maybe I'll attempt some type of repair.
1967 Chevelle SS
Old 07-23-2014, 10:59 PM   #4
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Id do something a little more rigid. That crossmember is what keeps the frame from twisting at the hangers.
Oldtruckfanatic is offline   Reply With Quote
Old 07-24-2014, 08:01 AM   #5
FlameOut
Thanks for the photo. I didn't realize I was missing such an important piece. I doubt I could find a donor piece in my area, so maybe I could fab up some type of 'I' beam to span that space.
I sure wish I had examaned this truck mor closely before dumping $1500 on it.
1967 Chevelle SS
Old 07-24-2014, 11:53 AM   #6
FlameOut
Upon further examination of my frame, it is strange that I don't have holes or rivets showing where that piece initially was? I think I can make something similar, using some 1/8" think steel I have. I'll use a 4" piece for the vertical, and 1-1/2" for the top and bottom horizontal, then make the triangle braces. I'll probably just weld it all in though rather than bolts/rivets.
I do have the one rivet doing nothing at the 5 1/2" mark, so I'm assuming that would be the center mark for my top horizontal piece
1967 Chevelle SS
Old 07-24-2014, 12:17 PM   #7
Oldtruckfanatic
Truck junkie
In all honesty my frame is a 2wd leaf spring chassis. The 4wd may have had a different crossmember there but it was there and served the same purpose. My pic was to show you what it does but you get the idea. Lots of guys build their own crossmembers so whatever you build just keep in mind what function Iit serves and im sure it will work out fine. here is a 2wd coil spring rear crossmember. The 5-1/2" is the top center rivet hole.
Old 07-24-2014, 03:06 PM   #8
Oldtruckfanatic
Truck junkie
I found more pics. Most of the ones I found show a crossmember like the one above for the 4X4 frames. Yours does have the holes for that.
Old 07-25-2014, 12:43 AM   #9
Ridgeback
Hope these may be of some help. First pic is top view, second pic is bottom view.
Ridgeback is offline   Reply With Quote
Old 08-01-2014, 02:50 PM   #10
FlameOut
Yes they do, thank you. Are the three holes on the rear, side for the bumper brackets? Also, is that hole on the top rear to bolt on the bed? I pretty much replaced the rear portion, so I'll have to re drill the necessary holes
1967 Chevelle SS
