Old 07-23-2014, 10:09 PM   #1
62lwbc10
58 original rear end?
Hey guys my rear end needs some work (that sounded weird) and I'm wondering how to confirm if it is in fact the correct original rear for the truck. It's leaking like a sieve from the front housing where it mates to the rear itself (not from the rear cover). So what do u look for to confirm the rear is correct for the truck and not swapped out from a different vehicle? My truck is a 58 half ton step.
Thanks!
Mark
62lwbc10 is offline   Reply With Quote
Old 07-23-2014, 10:12 PM   #2
Highsider
Highsider's Avatar
Re: 58 original rear end?
Crawl under there with your phone and take a couple of photos.
Most guys here will tell you to get the production numbers off the top of the passenger side tube.
My fat head won't let me see them easily and what I can see doesn't help verify the year and type.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 07-23-2014, 10:47 PM   #3
Daze57
Daze57's Avatar
yep picts will help ; you will prolly need to scrape off the dirt and crud to see the #s
Daze57 is offline   Reply With Quote
Old 07-24-2014, 10:26 PM   #4
_Ogre
_Ogre's Avatar
pinion bearings going bad, wallowed out the seal causing the leak
shop air compressor timer
Old 07-25-2014, 07:35 AM   #5
1project2many
Could just be rust accumulated on the yoke and destroyed the old seal. 'Specially if it's still leather.
1project2many is offline   Reply With Quote
Old 07-25-2014, 09:39 AM   #6
Speedbumpauto
Speedbumpauto's Avatar
If it has a rear cover, like he said, it's not the original diff. I believe all the 1/2 tons of the era had a drop out center section.
Speedbumpauto is offline   Reply With Quote
Old 07-25-2014, 09:58 AM   #7
1project2many
Original rear is C-clip with drop out center section. First page shows rear cover removed and C-clip removal process. Second page shows front of axle with removable pumpkin.
http://chevy.oldcarmanualproject.com...55ctsm0404.htm
http://chevy.oldcarmanualproject.com...55ctsm0406.htm
Old 07-25-2014, 10:32 AM   #8
Highsider
Highsider's Avatar
In my '57 3105 panel. Needs a new gasket, eh?
Not likely original.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 07-25-2014, 11:07 AM   #9
1project2many
Highsider,
No, not original. That's a "truck 12 bolt" used in many '70s and early '80s 1/2 ton pickups.
Old 07-25-2014, 12:12 PM   #10
Highsider
Highsider's Avatar
Originally Posted by 1project2many View Post
Highsider,
Makes sense, but it seems "light" for the 1975 C20 I understood was the donor vehicle. What do you all think?
Couple of months ago I crawled under the rear end, cleaned off the top of the passenger tube, copied the numbers and lost the paper.
I'll try next week when I replace my worn out Flowmaster.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 07-25-2014, 12:19 PM   #11
59chev
59chev's Avatar
Thanks!
Mark
When I still had the original rear in my 59 it was leaking from the pinion like you describe. I ended up getting a drivetrain shop to put in a new crush sleeve.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 07-25-2014, 03:19 PM   #12
1project2many
GM sells light duty 3/4 tons with semi-floating axles but they usually have 8 lug wheels. They used to sell a "Big 10" or "Heavy Half" pickup which could be had with a GVW just short of the 3/4 C20 truck's numbers (6200# vs #6400) and a theoretically higher payload capacity.
http://67-72chevytrucks.com/vboard/s...09&postcount=4
Old 07-25-2014, 04:13 PM   #13
Highsider
Highsider's Avatar
Those are my tail lights!
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 07-26-2014, 10:16 PM   #14
62lwbc10
Hey guys trying to post some pics but not having luck right now . Pinion looks dry . It's leaking from where the nuts of the housing attach to the rear .
Old 07-26-2014, 10:23 PM   #15
62lwbc10
Thanks 1project too many. According to the drawing in your link it's leaking from where the differential carrier mates to the axle housing . Is there a gasket there ? Since I'm going to be removing spindles etc. , what general maintenance should be done ? New seals? New bearings ? What else ? Not looking to rebuild at this time
Old 07-27-2014, 09:06 AM   #16
Rigmover
To bad i.m not closer to you I have one out of a 58 gmc that's just sitting in my garage complete with 3:90 gears would bolt rite in.
Rigmover is offline   Reply With Quote
Old 07-27-2014, 09:25 AM   #17
Rigmover
Yeh! you have the original carrier style rear end 10 bolt rear plate and 10 nuts on the front half that holds the carrier in when new they had gaskets today we use silicone.
Best thing to do is pull the inspection plate of the rear unlock locking bolt and undo the C clips that hold axles in and pull axles change out the axle seals and pull the front carrier out change out the pinion seal and reseal the carrier to housing with silicone then your good to go that's about the easiest fix that you can do .
Rick
Old 07-27-2014, 07:24 PM   #18
62lwbc10
Thanks Rick that makes sense so you think I should change the pinion seal too? It's not leaking at the moment. I also have a rear from a 55 that is ready to go. Do you think it would be better/easier to just switch rear ends or fix the current one?
Old 07-28-2014, 07:35 AM   #19
1project2many
If that rear hasn't been used in a long time then it's a good idea to change the pinion seal. The original leather seals were fairly tough but they won't put up with any rust on the yoke. The '55 rear swap is probably more work although if you're unsure of how to change the pinion seal I can understand not wanting to try.
