Old 07-23-2014, 10:13 PM   #1
scuderia
scuderia's Avatar
Driveshaft mounting question
Since my truck didn't come with a motor, trans or driveshaft I've got a few questions.
I've installed a SM465, measured the driveshaft length and gave the dims to the shop. They had a good donor driveshaft the right length with a slip joint and are installing new u-joints and balancing it tomorrow.
My question is concerning the hardware. He says he has the U-bolts but I seem to remember a couple of blots threaded in to the back of the trans... does the rear end and or the trans use U-bolts or the I'll call them U-brackets (the flat U's) that would bolt on with conventional bolts. Oh, and if someone can confirm that both ends use 1310 u-joints that would help too. The shop determined they were from the measurements I provided but...
Thanks,
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 07-23-2014, 10:58 PM   #2
66Submarine
66Submarine's Avatar
Re: Driveshaft mounting question
http://www.4wd.com/Jeep-Drivetrain-J...iCkaAlwb8P8HAQ
Something like these, you mean? The straps? I think SM465's (some of them, anyway) do have them.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 07-23-2014, 11:39 PM   #3
scuderia
scuderia's Avatar
Thanks, just looked at some of my pics and it seems the trans uses the straps and the diff uses U-bolts.
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
