Old 08-06-2003, 10:18 PM   #1
Blue4x4
Blue4x4's Avatar
power steering problems...help
After installing a new powersteering pump ,steering box and new hoses....I still don't have powersteering Any Ideas????
Blue4x4 is offline   Reply With Quote
Old 08-06-2003, 10:26 PM   #2
Class of 69
Class of 69's Avatar
Have you worked the air out of the system?? Usually best done with the front axle off the ground...turn lock to lock slowly...refill as neccessary.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 08-07-2003, 01:15 AM   #3
Blue4x4
Blue4x4's Avatar
I've driven about 40 mile on it now...you'd think it would be out of the system by now.........what do you mean"turn lock to lock slowly"?
Old 08-07-2003, 01:19 AM   #4
frost89434
frost89434's Avatar
It means turn all the way too one side then all the way to the other side.
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 08-07-2003, 04:54 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Do it with the engine off and turn the wheels by hand (not steering wheel).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-07-2003, 09:21 AM   #6
Dan72cst
Dan72cst's Avatar
Might work better with a v belt installed LOL haha
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 08-07-2003, 04:55 PM   #7
greg72
pwer steering
Don't be afraid to add fluid. I was shocked by the amount of fluid it took to fill mine. I must have turned it "lock to lock" over fifty times and it never felt loike power. Then it was like turning on a switch, finally enough fluid was added and it maintained a level. Be patient. Took me over an hour.
Greg72
greg72 is offline   Reply With Quote
Old 08-07-2003, 07:38 PM   #8
COBALT
COBALT's Avatar
Also remember that this is supposed to be a closed system like your brakes. Air won't "work its way out" like you think it will.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-07-2003, 07:52 PM   #9
SEVEND2
SEVEND2's Avatar
Is your Pump pully turning the pump? Is it a keyway pulley ot a nut? I had a nut style which just spun on the shaft and did not turn the pump. I had to change it for a keyway pump/pulley!
Make sure your pulley is tight on the pump!!
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
