07-24-2014, 05:00 PM | #1 |
Cab Mounts
I am in the process of replacing the cab mounts on my '70 C10. The washer that goes between the frame and upper bushing does not allow the new bushing to seat properly. Can anyone tell me what they did? Did you not use the original spacer? Did you replace it with a normal flat washer? Any help would be appreciated. Thank you.
07-24-2014, 05:04 PM | #2 |
Project Junkie! Fishing Poor!!
Re: Cab Mounts
Those are the crappy imported bushings. Buy USA made ones. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-24-2014, 05:05 PM | #3 |
Truck junkie
Re: Cab Mounts
That used to be molded to the old bushing. You dont need that particular washer anymore. When I switch to urethane I have never had those fit. I just dont use them. The urethane doesnt crush like the rubber does so if you measure it the thickness of the new bushing without that washer is about the same as a new rubber one with It. Maybe I have always been wrong but I buy those black urethane bushing kits at summit and use them without that washer and 10-12 trucks up to this point never had any problems.
07-24-2014, 05:43 PM | #4 |
Re: Cab Mounts
Thanks for replies. I bought the kit from LMC Truck.
07-24-2014, 05:47 PM | #5 |
Truck junkie
Re: Cab Mounts
Yeah I put that same set from lmc in the truck in my avatar. Didnt use them there either.
07-24-2014, 06:00 PM | #6 |
Re: Cab Mounts
Nice, now I can finish the install. Thank you guys.
07-25-2014, 11:22 PM | #7 |
Re: Cab Mounts
Oldtruckfanatic,
Did you use any of the original spacers? |
07-25-2014, 11:32 PM | #8 |
Truck junkie
Re: Cab Mounts
If I was using just the bushings I used everything but those locating washers. If I bought the whole kit use what I need to to get the gaps correct. I always keep all the washers and shims from the ones I take out because more often than not I end up having to shim somewhere to get the bed to cab gap even or get the fender to door gaps correct after changing them. I dont think ive ever been able to put a set of mounts in without having to do at least a little alignment. I will admit I have never bought an american made set like classic heartbeat mentioned but I grew up in body shops, my old man was a body and paint guy for 30 years and we pretty much always had to shim gaps when changing old mounts so I always figured it was part of the deal.
07-26-2014, 01:28 PM | #9 |
Re: Cab Mounts
You may or may not have to shim like Oldtruckfanatic says. These trucks are over 40 years old so I would expect that. However here is a picture of our made in the USA cushions. Compare those to the cheap imports and tell me what you would rather have on your truck. Good parts mean less problems. WES
07-26-2014, 01:35 PM | #10 |
Re: Cab Mounts
hey wes, had I known you offered these I wouldn't of waited 2 months to collect nos! they look great!
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
07-26-2014, 01:48 PM | #11 | |
Re: Cab Mounts
07-27-2014, 08:19 PM | #12 |
Re: Cab Mounts
They do look great. Thank you both oldtruckfanatic and classic heartbeat. Do you have a catalog available classic heartbeat?
07-27-2014, 09:12 PM | #13 | |
Re: Cab Mounts
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
07-28-2014, 12:07 PM | #14 |
Re: Cab Mounts
Just an on-line catalog at www.classicheartbeat.com WES
07-29-2014, 04:07 PM | #15 |
Re: Cab Mounts
Thank you
