Old 07-24-2014, 05:17 PM   #1
texasld
texasld's Avatar
Door Handles
I just found these on POL. They look great and seem like a fantastic price. Anyone have any?
http://www.performanceonline.com/bil...ndles-pol2100/
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 07-29-2014, 01:07 PM   #2
texasld
texasld's Avatar
Re: Door Handles
Bump?
1999 Jeep TJ
Old 07-30-2014, 12:09 PM   #3
kneesnthebreeze
Re: Door Handles
I have them, they look good. work good too. I also have the matching window roll down handle and I cannot keep the drivers side from falling off if anyone has any tricks. ill post a pic in a few min.
kneesnthebreeze is offline   Reply With Quote
Old 07-30-2014, 12:20 PM   #4
kneesnthebreeze
Re: Door Handles
door handle and window roll up handle
Old 07-30-2014, 03:32 PM   #5
texasld
texasld's Avatar
Re: Door Handles
Those do look pretty slick. How's the finish? I hope you get the issue with it falling off figured out?
Is the post worn out? I imagine they have a set screw, Have you tried thread locker? or is it clip style?
1999 Jeep TJ
Old 07-30-2014, 03:46 PM   #6
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: Door Handles
My door handles fall off all the time too but i think its cause i might be using 72 door handle mechanism, my handles used to not fall off but ever since i got new doors and unknown door mechanisms they will not seat in all the way unless i eather grind some metal off the shaft or ream the inside of the door handle.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 07-30-2014, 03:52 PM   #7
kneesnthebreeze
Re: Door Handles
the handles are nice shiny, they seem to be sturdy and good quality. I had thought about using thread lock or hell, even jb weld but I am worried about ever having to take them off. god forbid i have to remove the door panel to fix something.
Old 07-30-2014, 03:54 PM   #8
kneesnthebreeze
Re: Door Handles
they do have a set screw, i guess the notch in the post may be worn....ugh, sick of dealing with it.
Old 07-31-2014, 12:21 PM   #9
texasld
texasld's Avatar
Re: Door Handles
That should be easy to fix. Grind a flat spot or a grove, use medium thread locker, and you are ready to go!
1999 Jeep TJ
Old 07-31-2014, 01:04 PM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Door Handles
I have the same handles for sell on Face book. Mine are the Chrome plastic ones though. Look just like these. I have a set of billet ones now in the 71 and the thread lock did the trick from them falling off.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-31-2014, 01:18 PM   #11
hamjet
hamjet's Avatar
Re: Door Handles
I also have them. they came on the green 69 I bought this spring. it's the first thing I removed, didn't like them, they came loose and just felt cheap to me. ended putting stock ones back on...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
