Old 07-24-2014, 07:30 PM   #1
slikside
slikside's Avatar
Cranking difficulty with advanced timing??
I just advanced my timing from 8*BTDC to about 16*BTDC to try and get some better performance and fuel economy.
Now, when I go to start it, even cold, it struggles to crank over, similar to a heat soaked starter.
Should this be expected, or is something else going on coincidentally?
This is on a bone stock '72 350 C-10 with points ignition.
The throttle response is definitely better.
Thanks.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 07-24-2014, 07:44 PM   #2
Prescott
Re: Cranking difficulty with advanced timing??
Yes, it is predictable that the engine is fighting itself at 16 degrees. You could even blow a hole in one of your pistons. Try backing off to 12. It might behave a lot better.
Prescott is offline   Reply With Quote
Old 07-24-2014, 08:02 PM   #3
slikside
slikside's Avatar
Ouch! That would be bad. I'll do that.
Old 08-01-2014, 12:25 PM   #4
slikside
slikside's Avatar
Finally got around to doing this (haven't driven in the mean time), and yeah, much better now...thanks.
Old 08-01-2014, 07:02 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Bone stock engine and 16 degress is waaaayyyy too advanced. No "performance" to be gained. The neigborhood of 10 degrees will be fine... maybe even up to 12.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-02-2014, 09:07 AM   #6
bowtie72
bowtie72's Avatar
Your easiest upgrade for performance and economy would be a HEI dst. You will be amazed at the difference.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
