powerglide kickdown linkage
Trying to get my passing gear linkage setup on my powerglide. Does the linkage fit into the upper hole so it travels the same way as the throttle Vavle linkage or does it go into the lower hole so it travel the opposite direction of the TV linkage?
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
![]() Join Date: Jul 2007
Re: powerglide kickdown linkage
If I a correct it goes in the lower hole . You can move it when it is unhooked and it will have a slight spring tension. This is the direction it should move under acceleration.
Who Me?
Try this pic for reference.
![]() My KD cable is on the bottom.. There needs to be something that slips so it doesn't kick down till its wide open. Here is another close up pic. ![]()
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) Last edited by 61_FL_Apache; 07-26-2014 at 01:40 PM. |
