Old 07-25-2014, 07:45 PM   #1
Slinger60
Slinger60's Avatar
1970 Cruise Control
I personally pulled this complete cruise control off a 1970 c/20 truck. The diaphragm in the pot seems to work fine. If you want specific pictures let me know. If you want the speedo cable that goes to the tranny I can pull that as well. Unfortunately the blinker lever was broken at some time or another and it looks like the PO puts some JB weld on it with black tape. I pulled the tape off and it seems to be a pretty solid patch job. The button seems to work fine. $500.00 plus the ride.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 07-27-2014, 10:19 AM   #2
Slinger60
Slinger60's Avatar
Re: 1970 Cruise Control
Guess I am to high on this? Did a search for previous posts on this thought I was close. Any offers?
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 07-28-2014, 09:32 AM   #3
kaphillips
kaphillips's Avatar
Did you pull the vaccum release valve also under the dash also. Is there any rust on the chrome shaft on the stalk. I will offer $300 + ride.
kaphillips is offline   Reply With Quote
Old 07-28-2014, 10:14 AM   #4
Slinger60
Slinger60's Avatar
Here is a couple pictures of the blinker switch arm looks pretty clean. I didn't see any kind of valve under the dash. Took a picture of how the wiring was hooked up. In the lower right the single plug was hooked to fuse block and the other was hanging loose. If there is something missing maybe we could do $275.00 plus shipping?
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 07-28-2014, 10:17 AM   #5
Slinger60
Slinger60's Avatar
Guess it would help if I put the pictures on the post.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 07-28-2014, 10:46 AM   #6
kaphillips
kaphillips's Avatar
The parts that are missing is the vaccum release valve and its small L shaped mounting bracket that is mounted on the brake pedal arm above the stop light switch. I will take it as is for the 275 or will take it at 300 if you can find the release valve and its mounting bracket, Thanks LMK.
Old 07-28-2014, 10:46 AM   #7
Slinger60
Slinger60's Avatar
I found the release valve it was tucked up under dash on the break pedal.
Didn't see it before. If you would like I can post some pics of it. If not then I will take $300.00 plus shipping. I take money orders for payment PM me your info and I will do the same if you want it.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 07-28-2014, 10:51 AM   #8
kaphillips
kaphillips's Avatar
Oh and I would also like the lower spedo cable from the transducer to the tranny included, Thanks. If possible also the original hardware of all bolts and skrews. On the firewall is also a clamp the vaccum hoses were running thru. Thanks
Old 07-28-2014, 10:56 AM   #9
Slinger60
Slinger60's Avatar
I will pull the speedo for you and I have the hose bracket also and screws.
Sold to kaphillips pending payment Thanks.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
Old 07-28-2014, 10:58 AM   #10
kaphillips
kaphillips's Avatar
I will take it for the 300 to include the additional release valve, its mounting bracket on brake pedal arm, and the lower longer spedo cable to the tranny and its mounting clip on frame. Thanks PM was sent to ya.
Old 08-07-2014, 02:38 PM   #11
Slinger60
Slinger60's Avatar
Got your money order today shipped parts.
Thanks Shawn
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
Shawn
