![]() Join Date: Feb 2012
3/4 to 1/2 conversion
I am taking out the eaton and putting in a 12 bolt for the rear. In the front can I just leave the upper and lower control arms and change ball joints to put on 1/2 ton disc spindles?? I do know that I will have to change the center link to a 71-72 and tie rods ends of the same year.
Re: 3/4 to 1/2 conversion
The lower a arms won't work for u 1/2 ton ball joints don't fit in them. The uppers are OK though. Just put in the new 1/2 ton uppers and bolt in 1/2 ton lower arms. And then rest your correct on.
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
cool thanks
