open manifolds
All,
I am on the homestretch of a 5.3/4l60e swap into an 87 chevy 4x4. I need to have exhaust put on, and would like to know if the truck can be driven with open manifolds? Or if I had the factory downpipes with the front o2 sensors installed cut off in front of cats, can I drive it? Or should I just trailer to exhaust shop? Probably a 20 mile drive...thanks in advance! |
Re: open manifolds
Yes if you can stand the noise and you don't get a ticket. it will not hurt an engine to run straight from the exhaust manifolds. it will not harm the engine. Its just a myth that the cold air will warp the exhaust valves. that cast iron exhaust manifold is a large heat sink.
meowMEOWmeowMEOW
Re: open manifolds
Without the 02s it will dump pig rich and be very boggy. 20 miles would be a slightly nerve racking trip, and take you probably 30minutes (no freeway).
IF you can toss those front 02's into a test pipe, then your all good, even if its not perfect. The 02 will get some clean air sucked in from the short exhaust tip, but for the short ride you'd be fine.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Apr 2005
Re: open manifolds
+1
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Enjoying left field
Re: open manifolds
Rolling through town with no exhaust is the best part of a build. I agree on the front O2's though.
