I have a 1971 c10 long bed 4.1L L6 three on the tree. Ordered a replacement radiator from OReilly. Twice. Both were too deep. Despite the product page stating they included mounting brackets, neither did, and they were too deep to fit the existing brackets. I ordered this one first: http://www.oreillyauto.com/site/c/de...keyword=433369
Then the store guy ordered another one for me. Same price. Didn't fit either. I have the option of buying this one: http://www.oreillyauto.com/site/c/de...yword=radiator But it's $400 with shipping and who knows if it fits given the previous two items. I've still got the old radiator. It's brass. There is a small radiator shop just down the road that comes recommended by the OReilly guy. I plan to ask Monday how much they would charge to repair. In the meantime... has anyone here recently bought an off the shelf radiator for this style of truck successfully? Where did you go and how much did it cost? Just trying to evaluate options. Thanks! |
Re: Radiator replacement part?
It's four row core, yours is probably a two row core. All the forum vendors sell four row core radiator mounts and cushions. I'd get the correct mounts and cushions and use the four core.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 07-26-2014 at 09:38 PM. Reason: Typo |
Forum vendor? Do you have a link?
Classic Heartbeat, GMCPauls, Brothers.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: Apr 2013
My original radiator developed pinholes in one of the tanks...local radiator shop guy thought he fixed it but new pinholes developed...bought a four row one to replace my two row...got the four row brackets and they were too long to fit at the bottom...wound up getting the local radiator guy to build a two row for me...no problems since.
#6 | |
I don't know how common it is...he bought the two tanks from some supplier and brazed them on a two core middle he got somewhere else...it cost me about $300...I don't think he's a wizard, just experienced.
thats what all radiator shops did in the days before throwaway aluminum radiators with plastic tanks...it was called a recore...new core with your original tanks...now new chinese ones are cheaper so i guess its becoming a lost art...but if you find a shop thats been around a long time it shouldnt be a problem...but if i had to get a new one anyway i'd definately go bigger...beats the heck out of wishing you had if the truck winds up running hot after you're done
1970 short step c10 leaf spring 454 |
Can't think of why it would run hot if I have the original recored. Unless they restricted coolant or air flow or something.
When I test fitted that larger radiators with the built-in transmission coolers, they seemed to fit, except the brackets. I was a little worried about fan clearance though. With a deeper radiator, do I need a lower profile fan? |
Quit if it's not FUN!!!
I tried to post yesterday but my computer keeps crapping-out. I used one of the O'Reilly $185 radiators with my new GM crate motor. I do have a serpentine system with a clutch fan. I did have to rework the upper brackets (used a vise and a BFH to reshape them some), but otherwise it fit well and I have not had any issues this summer (90+ deg.). I have no fan shroud as the 5 blade clutch fan is too big to use the original (that's a late fall project ). I believe the O'Reilly (copper & brass) is a good buy and I would personnaly recommend it.Your L6 may be longer, but the clutch fan on my V8 is about 2-1/2" from the radiator.
MY MOTTO: Eat it all up, Wear it out, Use the last few drops, Spend all you've got, Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life ! . Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee) ![]() |
I put an orileys 4 row into my 70 l6 3 speed. No shroud, no clutch fan and I put an ac in it. Stays on 195 and I ordered new hold down brackets and cushions. Brackets could ve better but it works great. Never win a show but I drive it everyday.
#12 | |
#13 |
Where did you get the brackets?
#14 |
I am using a radiator Part #438161 from Advance Auto http://shop.advanceautoparts.com/p/r...161&showTitle= in my build. 3 row core, brass/copper construction. Top and bottom brackets fit like factory 1 or 2 row core.
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
#15 | |
#16 |
![]() Join Date: Dec 2011
We are a Gold Vendor supporter on this forum, and we make bolt-in radiators for your application:
http://67-72chevytrucks.com/vboard/s...d.php?t=590670 ![]() We include a built-in trans cooler at no cost (when requested), make them for any engine conversion at no additional cost, and we offer a forum discount! We are an American company, and we build these to order right here in the USA and they are all TIG welded with NO epoxy or glue. |
#17 |
I have a RnD. Its a really nice rad. Ill break their balls here and say it should come with a rad cap and petcock for the amount of money it costs but I'm happy with my purchase regardless.
![]() Shiny!! ![]() heres my post on being a tard about installing it. http://67-72chevytrucks.com/vboard/s...&postcount=142 |
#18 |
I'm running this $239. Engineered Cooling Products USA made aluminum 2 row, which is a direct replacement. Here in Texas on a 100degree day with A/C on, the engine temp is about 190. Check out my build thread for more pics etc.
http://www.speedcooling.com/1967-197...r/prod_38.html ![]() ![]() ![]() ![]()
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 07-29-2014 at 12:02 AM. |
#19 | |
#20 |
I went down the road to the local radiator guy. For $300 (and a couple of cents), he recored with a new 2 core on my old tanks. He says he replaced the gaskets and he definitely replaced the drain valve too (feels very crisp now - was a mess before - couldn't turn by hand and had to use a wrench). I asked how long I could expect it to last, and he said for the lifetime of the truck, probably. I don't know about that, but I'm pretty happy. Fit like a glove in the existing mounts.
I've been driving it for a couple of days now and it seems to be working great. |
#21 |
![]() Join Date: Nov 2007
#22 |
I wish I would have seen this thread earlier, I could have saved time and hassle of returning the same two radiators to oreilley's. I'm working with a 68 gmc with a 327 and an automatic, but I couldn't make either of them fit. Guess I'll try the one posted from advance auto. I really don't want to spend $300+ on a Radiator.
"The Mustang’s front end is problematic, get yourself a Firebird. "- Red Forman |
#23 |
It's hand crafted by my co-builder. Started out as a flat piece of aluminum and 2 OEM fans from a 2003 Pontiac Grand Am. You'll find fabrication details in my build thread.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#24 |
![]() Join Date: Sep 2005
I bought a griffin all aluimn rad for 267 dollars csuse my stocker was leaking the rad shop said with the price of copper it was going to be like 450 dollars to recore it
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#25 |
keep an eye on the griffin for leaks, as I believe they use epoxy at the core to tank connection
