Old 07-26-2014, 10:59 PM   #1
MYBAD66
MYBAD66's Avatar
column issues
looks like I have a column switch issue...wondering if anybody knows what columns will fit into a 66 3/4ton with no problems/minimal work
94 Chevy K1500 350
66 GMC c2500 305
MYBAD66 is offline   Reply With Quote
Old 07-26-2014, 11:02 PM   #2
pimpston65
pimpston65's Avatar
Re: column issues
what do you mean column switch?
pimpston65 is offline   Reply With Quote
Old 07-26-2014, 11:13 PM   #3
MYBAD66
MYBAD66's Avatar
Re: column issues
the signal switch in the column all wires are spliced and its just a mess that I think a new start on it would be better than redoing someones mess...i've heard 70's or 80's van columns will work but the shaft is a tad bigger? but the wiring harness will plug right in and
94 Chevy K1500 350
66 GMC c2500 305
Old 07-26-2014, 11:16 PM   #4
pimpston65
pimpston65's Avatar
Re: column issues
why not just change the turn signal harness and the harness down to the main harness, bet its easier then a complete swap. i keep it oem cuz murphys law runs my life...post some pics, maybe forum members can find an easier solution
Old 07-26-2014, 11:25 PM   #5
MYBAD66
MYBAD66's Avatar
Re: column issues
its a weird mishmash of parts and a complete rats nest at this point...plus its dark out by now so i'll get some for yall tomorrow and see what I can do. would you mind explaining a little more on what you mean by changing it to the main harness?
94 Chevy K1500 350
66 GMC c2500 305
Old 07-27-2014, 12:02 AM   #6
pimpston65
pimpston65's Avatar
Re: column issues
the turn signal setup has its harness that connect to the rest of the main harness. if you have a spare harness you can just swap wiring, and replace the turn signal part with a new setup round $60 with the upper shaft bearing...
Old 07-27-2014, 12:03 AM   #7
pimpston65
pimpston65's Avatar
Re: column issues
or do you have a different type of turn signal thats not in the column? kinda like attached with a clamp.
