72C10 wheel lug pattern
My 72 has 6 lugs in the rear and 5 in the front is this normal can someone give me the skinny on this?
Re: 72C10 wheel lug pattern
You probably have an older axle from a '70 or older half ton. You could change the axle to a '71 or newer or you may be able to use axle shafts and brake drums from an older truck. Be sure to compare the parts to ensure fit b4 you buy them as there are some variations.
So the 72's were all 5 lug on the half ton trucks?
I believe that to be correct mine is a 5 0n 5 bolt pattern.
![]() Join Date: Sep 2007
yep. It sounds like the previous owner swapped out the five lug rearfor a much easier to find 67 to 70 rearend. Do you have leaf or coil springs?
1967custom |
My 72 GMC has 5x5 front and rear.
I have coil springs
