Old 07-27-2014, 03:16 AM   #1
Sierra72
71-72 gmc chev front rear diffs
Looking to buy 71-72 front and rear diffs.
Have 3/4 ton diffs out of a 77 3/4 ton truck, want to go back to 6 bolt.
Does anyone know if 73 and up would work, and what years match.
need something out f Vancouver, British Columbia area.
Ray
Sierra72 is offline   Reply With Quote
Old 07-28-2014, 10:38 AM   #2
turp mcspray
turp mcspray's Avatar
Re: 71-72 gmc chev front rear diffs
Front is a bolt in deal. In 73 the rears got different perch spacing, and the shock locations changed.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-29-2014, 12:38 AM   #3
Jdubs71
Jdubs71's Avatar
Like Turp said front is a direct bolt in. Rear perches on 73 and up 1/2 ton are 42.5" on center and you need them to be 40.5" on center. If you use a 1 ton or 14 bolt 73 & up i believe the perches will be 40.5" but you will have to relocate shock mounts.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
