Front end conundrum
Thought I started this thread already, but cannot find it.
I bought a 68 C10 rolling chassis. It has a 5 bolt lugs on the front, not sure how it was done. I want to identify the configuration to be sure to get the right replacement parts. It has 1 1/4" thick front rotors, and non-rubber a-arm bushings. Questions: 1. Can I identify tie rod ends and center link by diameter? 2. Any way to identify the steering knuckles? 3. If it has 73 or newer cross-member on the front, will some of the attachment holes be elongated? I've seen 73 and up front suspensions at the U-pull it with the non-rubber a-arm bushings, not sure when that started. 4. Can I identify ball joints by the bolt diameter? 5. Any other tips appreciated. TP (mechanicalman) Last edited by mechanicalman; 07-27-2014 at 11:57 AM. Reason: Left out a question |
