Old 08-07-2003, 01:24 AM   #1
'89Z71
'89Z71's Avatar
gear ratio questions
I have an '89 GMC Sierra Z71 with the stock 10 bolt and was wondering what size gears it has in it? I found this link on the board gear ratio chart and according to what it says: sinse my truck runs about 2600(give or take a bit)rpm@65mph with 33" tires in 4th gear I should have anywhere from 3.91 gears to 4.11's. Is this correct???? From what others are saying i should have gears like 3.08's or something small like that in my truck. Any help is wanted (IM VERY CONFUSED:p ) Thanx in advance, DK
'89 GMC Sierra Z71 -"Scream'n Demon"
*** LOUD PIPES SAVE LIVES ***
My Truck
'89Z71 is offline   Reply With Quote
Old 08-07-2003, 08:32 AM   #2
LonghornJeff
EZEKIEL 25:17
LonghornJeff's Avatar
GEAR RATIO =RPM X TIRE DIAMETER DIVIDED BY MPH X 336
DONT FORGET YOU HAVE OVERDRIVE SO MULTIPLY BY .70
THE FORUMLA ASSUMES 1 TO 1 FINAL DRIVE
LOOKS LIKE THE 3.08s TO ME
68 CHEVELLE(HORSESHOE)
69 LONGHORN 396
70 NOVA 454(FOR SALE)
71 SWB 307
71 EL CAMINO 383
72 GMC JIMMY 350
87 BLAZER 350 WIW?
http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM
Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists.
The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers...
LonghornJeff is offline   Reply With Quote
Old 08-07-2003, 08:37 AM   #3
LonghornJeff
EZEKIEL 25:17
DO YOU HAVE A AUTOMATIC....IF SO THEN MULTIPLY BY .70
IF YOU ARE RUNNING A MANUAL THEN CHECK SPEED AND RPM IN FOURTH GEAR
69 LONGHORN 396
71 SWB 307
71 EL CAMINO 383
72 GMC JIMMY 350
87 BLAZER 350 WIW?
Old 08-07-2003, 12:02 PM   #4
'89Z71
'89Z71's Avatar
I have a manual and yes i ran in fourth gear. All the info is above in my first post.
My Truck
Old 08-07-2003, 12:31 PM   #5
Blazer1970
Blazer1970's Avatar
If the gears haven't been changed, you can tell from the RPO codes on the sticker inside the glove box.
GU4 = 3.08
GU6 = 3.42
GT4 = 3.73
GT5 or GT8 = 4.10
Blazer1970 is offline   Reply With Quote
Old 08-07-2003, 01:08 PM   #6
'89Z71
'89Z71's Avatar
the gears gould have been changed but im not sure. Thanx for the codes! I'm going to go check them right now
My Truck
Old 08-07-2003, 01:12 PM   #7
'89Z71
'89Z71's Avatar
Well i just checked and it is a GT4, so 3.73 gears. Does this sound about right to you guys? Thanx, DK
My Truck
Old 08-07-2003, 01:15 PM   #8
'89Z71
'89Z71's Avatar
O, and will the 3.73's be ok for 35" tires?
My Truck
Old 08-08-2003, 12:10 AM   #9
'89Z71
'89Z71's Avatar
TTT
My Truck
Old 08-08-2003, 07:59 AM   #10
Blazer1970
Blazer1970's Avatar
3.73s with 35s is far from ideal with the O/D tranny, but it will work. I ran 33s with 3.42s on a Suburban for a while and it was OK. You will not want to use O/D except when you are on the highway going 65 mph or over. Just put it in D for normal driving. 4.10s or even 4.56s would be better for 35s with a 700R4/4L60.
