07-28-2014, 01:46 AM | #1 |
Who's the authority on one wire alternator conversion
I am in the middle of changing my alternator over to a one wire and no external alternator, do any of you have a good schematic or instruction material any help would be appreciated.
07-28-2014, 02:48 AM | #2 |
Re: Who's the authority on one wire alternator conversion
Covered a bunch of times in the electrical section, probably also in the FAQ's section.
Schematic's are posted allover Also open the advanced search and type in key words.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
07-28-2014, 10:03 AM | #3 |
Thanks, swamp rat I'm looking
07-28-2014, 10:22 AM | #4 |
I did mine. All I did was remove the regulator. Removed all wires from the harness that were no longer used and hook up the single 10 gauge wire to the single post on the alt. works flawless. I love one wire alts. Use them on all my old cars
07-28-2014, 12:18 PM | #5 |
Msgt USAF Ret
There is some really good reading here on one wire alternators as well as other electrical stuff. BTW if you have a charging light it will no longer work with a one-wire alternator.
http://www.madelectrical.com/electrical-tech.shtml
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
07-31-2014, 08:24 PM | #6 |
I vote to NOT do the 1-wire swap and instead set up your charging system for the proper remote voltage sensing as Mark Hamilton discusses on his site. I go a little further with my 4ga upgrade to handle multiple high powered loads that even an SI charging system isn't designed to handle very well. It has more to do with the way GM ran their wiring which lends itself to huge voltage drop issues as well as older SI alternator designs having relatively slow reacting "window times" with regards to how fast the regulator stabilizes the system voltage whenever a load is placed on the circuit-hitting a window switch, electric fan turning on via a relay, etc. Mark and I have discussed a variety of topics from time to time about it over the phone....great guy to talk with!
